WMS Server - URL question on IIS
Ed McNierney
ed at TOPOZONE.COM
Tue Dec 7 19:36:33 EST 2004
Tanya -
That code needs to go wherever you want the resource to live - wherever
you want the URL to point. If you saved it in the root of your Web
directory and you named it "obfuscate.asp" then your WMS URL might be:
http://www.mymapserver.com/obfuscate.asp
As Rich pointed out, IIS is normally configured to look for a file named
default.asp in a directory, and so it will automagically open that file
if you give IIS a URL that points to a directory. Therefore, if you
saved this ASP code in the root of your Web directory and named it
"default.asp" as he suggests, you could use either:
http://www.mymapserver.com/default.asp OR
As your online resource URL. Assuming, of course, that you replace
www.mymapserver.com with your server's name.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 978 251-4242 Fax: +1 978 251-1396
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of TC Haddad
Sent: Tuesday, December 07, 2004 5:52 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] WMS Server - URL question on IIS
this feels like a pretty ignorant question, but i'm not that familiar
with IIS, and i'm hoping someone can help. we have a Win2k IIS 5 box
which we have GetMap and GetCapabilities requests working on. now we're
interested in masking the URL a bit so it's a bit tidier. in the
WMS-How-To there is a ASP script provided (see below) - but where does
the script go in IIS if we want to implement this option? Any help would
be great, tanya
MapServer version 4.2.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
ASP script example from WMSServerHow-To:
http://mapserver.gis.umn.edu/doc42/wms-server-howto.html#onlineresourceu
rl
Server.ScriptTimeout = 360
strRequest = Request.ServerVariables("QUERY_STRING")
strURL = "http://myserver/cgi-bin/mapserv.exe?
map=C:\Inetpub\wwwroot\WMS\mymap.map&" & strRequest
Dim objHTTP
Set objHTTP = Server.CreateObject("MSXML2.ServerXMLHTTP")
objHTTP.open "GET", strURL, false
objHTTP.send ""
Response.ContentType = objHTTP.getResponseHeader("content-type")
Response.BinaryWrite objHTTP.responseBody
Set objHTTP = Nothing
