itemnquery (qstring) search specifications -- "=" vs like
{Scanned} {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Thu Dec 9 20:18:09 EST 2004
It's regexp, try /^A$/
Bye
Zoltan
On Thu, 9 Dec 2004, Geographic Resource Solutions wrote:
> Richard-
> Thanks for the reply-
> Sorry for my confusion - I typed a "|" when it should have been a "/" I
> appear to have the syntax correct for making a match.
> If I seach for qstring=/A/ I get every land use type with that as part
> of the use designation
> including the 'AC-RW' - I don't want the 'AC-RW' match as it is not of
> type 'A'
> If I leave it as A, /A, or A/ I get "no records found" - How do I get
> a match for only the polygons of type 'A' and none of the others with an
> A in the type ?
> I need to be able to specify an absolute equality/match for character
> fields as opposed to a match based on a portion of any character value in
> that field. Are there other characters to include in the qstring that
> specify what type of match to perform ?
> Ken
> At 12:02 PM 12/9/2004 -0700, you wrote:
> >On Thu, 9 Dec 2004 08:34:26 -0800, Geographic Resource Solutions
> ><grs at grsgis.com> wrote:
> >> Dear list-
> >> I have searched the list for something like this and have come up
> empty.
> >> After getting everything to work I find my queries are not returning
> the
> >> features I desire. Rather they are returning too many 'hits.' The
> search
> >> expression is obviously operating as an SQL 'like' with wildcards at
> each
> >> end of the specified value rather than an SQL '='. For example,
> >> qstring = |101011|
> >> when applied to my parcel data returns all parcels that have the
> 101011
> >> characters present in their value, no matter where they are in the
> string.
> >> Thus I get parcels 12 parcels starting with 101011, but I also get
> parcels
> >> like 522101011' which I do not want.
> >> Similarly, when searching for a land use code of 'A' I return all
> the 'A'
> >> land use polygons, but I also get all the 'AC-WR' and any others that
> have
> >> an 'A' in them which I do not want located.
> >> So my question is:
> >> Am I doing somethin wrong ? How do I specify an expression that
> should be
> >> an equality '=' rather than a 'like' ? Is there a wildcard that can
> be
> >> included in the expression statement so that it operates as I define
> it
> >> (e.g. (101011% or A%)) rather than assuming wildcards are part of the
> >> expression at beginning and end. This is obviously not following
> standard
> >> SQL formatting so what are the definitions that apply to expressions
> and how
> >> can I generate the query results I need. Queries that return improper
> >> results make the programmer look rather foolish - and of course I
> would like
> >> to avaoid that appearance ! I figure there must be a way - and if
> not, then
> >> there really needs to be a way - but what is it ?
> >> Thanks in advance,
> >> Ken Stumpf
> >> 1125 16th Street, Suite 213
> >> Arcata, CA 95521
> >> Phone: (707) 822-8005
> >> Fax: (707) 822-2864
> >> www.grsgis.com
> >Mapserver uses regular expression syntax, not SQL syntax, on the
> >qstring. Try leaving off the pipe characters for starters, the apply
> >regex symbols.
> >Regards,
> >Richard Greenwood
> >richard.greenwood at gmail.com
> >www.greenwoodmap.com
> Arcata, CA 95521
> Fax: (707) 822-2864
> www.grsgis.com
