itemnquery (qstring) search specifications -- "=" vs like
Richard Greenwood
richard.greenwood at GMAIL.COM
Thu Dec 9 19:32:35 EST 2004
On Thu, 9 Dec 2004 12:40:00 -0800, Geographic Resource Solutions
<grs at grsgis.com> wrote:
> Richard-
> Thanks for the reply-
> Sorry for my confusion - I typed a "|" when it should have been a "/" I
> appear to have the syntax correct for making a match.
> If I seach for qstring=/A/ I get every land use type with that as part of
> the use designation
> including the 'AC-RW' - I don't want the 'AC-RW' match as it is not of
> type 'A'
> If I leave it as A, /A, or A/ I get "no records found" - How do I get a
> match for only the polygons of type 'A' and none of the others with an A in
> the type ?
> I need to be able to specify an absolute equality/match for character
> fields as opposed to a match based on a portion of any character value in
> that field. Are there other characters to include in the qstring that
> specify what type of match to perform ?
> Ken
1. Try putting it quotes, single or double.
2. Where are you putting this qstring=A? Typically a "qstring=x" is
specified in the URL and passed to mapserver. And then your map file
would have a FILTER and FILTERITEM for that layer.
3. Remeber that you're working with regex expressions, not SQL statements.
Regards,
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
