Decode values in CGI query mode
Daniele Margotti
margottid at COMUNE.LUGO.RA.IT
Mon Dec 13 04:44:30 EST 2004
Hi list,
I use CGI MapServer for browsing and querying shapefile-based maps.
This is the version:
<!-- MapServer version 4.2.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE -->
In a shapefile I have a numeric field which is a codified value (i.e.:
values 0, 1, 2, ... each corresponding to a very long description of the
attribute).
I don't want / can't modify the shapefile and/or the .DBF file, and I'd
like to set this long description ONLY ONE TIME in the mapfile, so that
when I query the map I don't see the anonymous numeric values but
MapServer decodes and substitutes them with my more exausting long
description.
Is it possible to set these substitutions in the mapfile?
Thank you,
Daniele
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041213/45b1291d/attachment.html
