R: [UMN_MAPSERVER-USERS] Decode values in CGI query mode
Daniele Margotti
margottid at COMUNE.LUGO.RA.IT
Tue Dec 14 04:14:21 EST 2004
Thank you very much!
The use of CSV file is the ideal solution for me, since I have only few
different values to decode.
Bye,
Daniele
-----Messaggio originale-----
Da: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Per
conto di Steve Lime
Inviato: lunedì 13 dicembre 2004 20.32
A: MAPSERVER-USERS at LISTS.UMN.EDU
Oggetto: Re: [UMN_MAPSERVER-USERS] Decode values in CGI query mode
Not in the mapfile, but you can do this using a MapServer join object.
You could set up an external database (MySQL, DBF and comma seperated
value files are supported) to hold the code and the long name. You
access the joined column then in your template.
So, if you have a file that looks like:
0,Long name for code 0
1,Long name for code 1
You could define something like this in your mapfile:
JOIN
NAME "longname"
CONNECTIONTYPE CSV
TABLE "lookup.txt"
FROM "CODE"
TO "1" # refers to column 1
END
and in your query template perhaps something like:
[CODE]: [longname_2]
where [CODE] is from the dbf file and [longname_2] refers to the second
column in the longname join. Csv joins don't have column names hence the
column references. Hope this helps.
Steve
>>> Daniele Margotti <margottid at COMUNE.LUGO.RA.IT> 12/13/2004 3:44:30
AM >>>
Hi list,
I use CGI MapServer for browsing and querying shapefile-based maps.
This is the version:
<!-- MapServer version 4.2.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE -->
In a shapefile I have a numeric field which is a codified value (i.e.:
values 0, 1, 2, ... each corresponding to a very long description of the
attribute). I don't want / can't modify the shapefile and/or the .DBF
file, and I'd like to set this long description ONLY ONE TIME in the
mapfile, so that when I query the map I don't see the anonymous numeric
values but MapServer decodes and substitutes them with my more exausting
long description.
Is it possible to set these substitutions in the mapfile?
Thank you,
Daniele
