SWIGMapscript: processLegendTemplate throws error
Umberto Nicoletti
unicoletti at PROMETEO.IT
Wed Dec 15 02:49:27 EST 2004
On Mon, 2004-12-13 at 10:16 -0700, Sean Gillies wrote:
> Can you not try and catch, and pass in the case of an exception?
> This is essentially what happens with shp2pdf.
I have modified the DrawMap example as follows:
mapObj map = new mapObj(args[0]);
map.getImagecolor().setRGB(153, 153, 204);
styleObj st = map.getLayer(1).getClass(0).getStyle(0);
st.getColor().setHex("#000000");
outputFormatObj pdf=new outputFormatObj("pdf","pdf");
//outputFormatObj flash=new outputFormatObj("SWF","swf");
imageObj img=null;
try {
map.setOutputFormat(pdf);
//map.setOutputFormat(flash);
//map.getScalebar().setStatus(mapscript.MS_OFF);
System.out.println("Scalebar status:
"+map.getScalebar().getStatus());
img = map.draw();
System.out.println("The map will be drawn to:"+args[1]);
} catch(Throwable e) {
img.save(args[1], map);
but, as I suspected it does not work because draw() does not return and
img is therefore null.
I attach a patch for this PDF specific error. Let me know if you like it
or if we should work it out differently.
Regards,
Umberto
> I still have a hard time believing that the templating can work.
> The mapscript function expects char** and Andreas is passing a
> Java array of strings. Does Swig-java translate these
> automatically?
> The templating functions certainly do not work for Perl and Python.
> Sean
> On Dec 13, 2004, at 10:08 AM, Umberto Nicoletti wrote:
> > Sean,
> > the problem is in maphash.c around line 126. There you can see that
> > mapserver sets an error because the user tried to free an already null
> > hashTable and this causes Java mapscript to bail out with an exception,
> > while in earlier versions the error was ignored.
> > This is a consequence of my patch for handling mapserver errors as
> > exceptions in java mapscript. In fact I have faced a similar error
> > while
> > trying to produce pdf output from Java mapscript. The same map file was
> > working fine with shp2pdf because shp2pdf was just ignoring the error.
> > I believe that my patch, while trying to prevent the java virtual
> > machine from crashing altogether, ends up throwing exceptions when
> > instead it is dealing with a warning (even tough it is an error in
> > mapserver terms).
> > What we need is probably some fine tuning for situations like this...
> > Apologies to Andreas if this is not helping you, but I am just trying
> > to
> > generalize your problem so that we can work out a (hopefully) better
> > solution.
> > Please let me know what you think about this,
> > Umberto
> > On Mon, 2004-12-13 at 07:23 -0700, Sean Gillies wrote:
> >> On Dec 13, 2004, at 6:14 AM, GeoIT wrote:
> >>> Dear experts,
> >>> I used mapObj.processLegendTemplate successfully with mapserver 4.0.
> >>> Now I
> >>> try to upgrade to version 440 and get the following error using this
> >>> method:
> >>> Java.lang.UnknownError: Can't free NULL table
> >>> Any ideas ?
> >>> The code is:
> >>> public String getProcessedLegendTemplate(mapObj mapObject) {
> >>> String[] names =3D {"img", "legend", "scalebar", =
> >>> "ref"};
> >>> String[] values =3D {"", "", "", ""};
> >>> int numItems =3D 4;
> >>> return mapObject.processLegendTemplate(names,
> >>> values,numItems);
> >>> regards
> >>> Andreas Paukner-Ruzicka
> >> Andreas,
> >> I am very surprised that you could call processLegendTemplate
> >> with MapServer 4.0. It was my understanding that Java mapscript
> >> was broken at that time.
> >> Please enter a report into the MapServer Bugzilla under the
> >> SWIG mapscript component and I will investigate and try to fix
> >> it before the next release.
> >> cheers,
> >> Sean
> >> Sean Gillies
> >> sgillies at frii dot com
> >> http://users.frii.com/sgillies
> > Umberto Nicoletti <unicoletti at prometeo.it>
> > Prometeo SRL
Prometeo SRL
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041215/16dee03c/patch-pdf-bitmapfonts.bin
