SWIGMapscript: processLegendTemplate throws error
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Wed Dec 15 13:39:55 EST 2004
I'm no expert but I've been learning about swig lately and I can't see anyway you ever got this to work with any version of mapserver and swig.
Could you send me the mapObj.java you compiled into your jar as well as what version of SWIG you had installed? Because it ever working is indeed extremely odd.
I'm not a mapserver developer but I sure am curious.
Thanks,
-e
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of GeoIT
Sent: Monday, December 13, 2004 6:15 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] SWIGMapscript: processLegendTemplate throws error
Dear experts,
I used mapObj.processLegendTemplate successfully with mapserver 4.0. Now I try to upgrade to version 440 and get the following error using this method:
Java.lang.UnknownError: Can't free NULL table
Any ideas ?
The code is:
public String getProcessedLegendTemplate(mapObj mapObject) {
String[] names = {"img", "legend", "scalebar", "ref"};
String[] values = {"", "", "", ""};
int numItems = 4;
return mapObject.processLegendTemplate(names,
values,numItems);
regards
Andreas Paukner-Ruzicka
Geo-IT GmbH - Geoinformatik, IT-Services
Guggenberg 3, D-82380 Peissenberg
Tel: 08803-498372, Fax: 08803-498373
eMail: info at geo-it.com - Homepage: http://www.geo-it.com
> -----Ursprüngliche Nachricht-----
> Von: Karel Cernohorsky [mailto:cernohor at CENTRUM.CZ]
> Gesendet: Montag, 13. Dezember 2004 13:31
> An: MAPSERVER-USERS at LISTS.UMN.EDU
> Betreff: [UMN_MAPSERVER-USERS] Image output pixel coordinates
> Hello folks,
> I need an advice,
> I am trying to develop small java application
> where I am displaying a map as a background.
> I wasn't able to succesfuly compile and rum Java mapscript on
> Windows platform. (I will post some questions to this problem later)
> Now I am using php to prepare the map using PHP/MapScript. And this
> page is returned as an png image.
> I have a set of GPS positions and I can display them as a
> points in the map using php (which is able to set another
> layer and write points symbols there.)
> $image=$map->draw(); $layer=$map->getLayerByName('add_points');
> for ($n = 0; $n <sizeof($map_pointx); $n++) {
> $point[$n] = ms_newPointObj();
> $point[$n]->setXY($map_pointx[$n],$map_pointy[$n]);
> $point[$n]->draw($map,$layer,$image,0,'yuhuu');
> Is there any way how can I get the pixel coordinates of each
> point object I have drawn in the "add_points" layer?
> My output projection is default
> PROJECTION
> "proj=latlong"
> "ellps=WGS84"
> "datum=WGS84"
> END
> I thought It could be easy to simply calculate them from
> height and width and from the min and max latitude and
> longitude of the returned map extent., am I right or wrong?
> Can anybody help me or give me any advice?
> Looking forward to read your hints,
> Karel Cernohorsky.
> Karel
> Odchozí zpráva neobsahuje viry.
> Zkontrolováno antivirovým systémem AVG (http://www.grisoft.cz).
> Verze: 6.0.802 / Virová báze: 545 - datum vydání: 26.11.2004
