projection problem
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Wed Dec 15 15:32:26 EST 2004
Well it's a right of passage for mapserver users.
STATUS DEFAULT means always on so when you switch to mode=map it will
still be on
STATUS ON really means that it can be controlled externally with the
layers= CGI parameter.
-e
-----Original Message-----
Sent: Wednesday, December 15, 2004 1:10 PM
To: Ethan Alpert
Subject: Re: [UMN_MAPSERVER-USERS] projection problem
That was it! Why on earth would that break things?
Thanks a lot!
-Camden
On Wed, 15 Dec 2004 13:03:45 -0700, Ethan Alpert
<ealpert at digitalglobe.com> wrote:
> Did you try setting STATUS DEFAULT instead of STATUS ON?
> -e
> From: Camden Daily [mailto:cdaily at gmail.com]
> Sent: Wednesday, December 15, 2004 1:00 PM
> To: Ethan Alpert
> I tried feet as well, but to no avail. Could you point me to where I
> can look up the EPSG code for my projection?
> Thanks,
> -Camden Daily
> On Wed, 15 Dec 2004 12:51:44 -0700, Ethan Alpert
> > Looks like you have units meters and the data has units feet.
> > Also is there NAD support in your version of libproj4? I seem to
> > recal
> > there are legality problems wrt distribution of NAD support in
> > libproj4 and you need to dowload it separately.
> > You may also want to look up the EPSG code for your projection and
> > try
> > that rather than the proj parameters.
> > -e
> > Sent: Wednesday, December 15, 2004 12:49 PM
> > To: Ethan Alpert
> > Yeah, I've given that a shot as well, but no luck!
> > Thanks though,
> > -Camden Daily
> > On Wed, 15 Dec 2004 12:46:23 -0700, Ethan Alpert
> > > Have you tried putting the projection BLOCK in the MAP block
> > > rather than the LAYER?
> > > -e
> > > From: UMN MapServer Users List
> > > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> > > On Behalf Of Camden Daily
> > > Sent: Wednesday, December 15, 2004 12:11 PM
> > > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > > Subject: [UMN_MAPSERVER-USERS] projection problem
> > > Hi all. I'm working on a mapserver application, and running into
> > > issues with projections. I have absolutely no background in GIS,
> > > but I've managed to hack together a pretty good map application
> > > using tiger/line data, which I believe is in latlong format.
> > > However, I have a new shapefile I've grabbed for the mass transit
> > > in
> > > my city, and it's in a completely different projection, and I have
> > > no idea how to get it to work in mapserver.
> > > When I run ogrinfo on my new shapefile I get the following:
> > > INFO: Open of `CTA_Line.shp'
> > > using driver `ESRI Shapefile' successful.
> > > Layer name: CTA_Line
> > > Geometry: Line String
> > > Feature Count: 186
> > > Extent: (1101584.450000, 1841973.900000) - (1186739.850000,
> > > 1969991.020000) Layer SRS WKT:
> > > PROJCS["NAD_1983_StatePlane_Illinois_East_FIPS_1201_Feet",
> > > GEOGCS["GCS_North_American_1983",
> > > DATUM["North_American_Datum_1983",
> > > SPHEROID["GRS_1980",6378137.0,298.257222101]],
> > > PRIMEM["Greenwich",0.0],
> > > UNIT["Degree",0.0174532925199433]],
> > > PROJECTION["Transverse_Mercator"],
> > > PARAMETER["False_Easting",984250.0],
> > > PARAMETER["False_Northing",0.0],
> > > PARAMETER["Central_Meridian",-88.33333333333333],
> > > PARAMETER["Scale_Factor",0.999975],
> > > PARAMETER["Latitude_Of_Origin",36.66666666666666],
> > > UNIT["Foot_US",0.3048006096012192]]
> > > CTALINE_ID: Integer (11.0)
> > > ROUTE: String (50.0)
> > > COLOR: String (7.0)
> > > SHAPE_LEN: Real (19.11)
> > > SHAPE_FID: Integer (9.0)
> > > For my mapfile, I'm using:
> > > MAP
> > > NAME Chicago
> > > STATUS ON
> > > DEBUG ON
> > > SIZE 300 300
> > > IMAGETYPE PNG
> > > IMAGECOLOR 240 240 240
> > > SHAPEPATH "/web_system/data"
> > > FONTSET "/web_system/fonts/fonts.list"
> > > EXTENT 1101584.450000 1841973.900000 1186739.850000
1969991.020000
> > > UNITS METERS
> > > WEB
> > > LOG "/web_system/logs/mapserver.log"
> > > IMAGEPATH "/web_system/tmp/"
> > > IMAGEURL "/tmp/"
> > > END
> > > LAYER
> > > NAME "cta_line"
> > > TYPE LINE
> > > STATUS ON
> > > DEBUG ON
> > > DATA "CTA_Line"
> > > CLASS
> > > COLOR 0 0 0
> > > END
> > > PROJECTION
> > > "proj=tmerc"
> > > "lat_0=36.666666"
> > > "lon_0=-83.333333"
> > > "x_0=984250.0"
> > > "y_0=0.0"
> > > "k=0.999975"
> > > "ellps=GRS80"
> > > "datum=NAD83"
> > > "to_meter=0.3048006096"
> > > "no_defs"
> > > END
> > > END
> > > END
> > > Of course, no matter how hard I try, my map always comes up blank.
> > > If
> > > anyone can see anything obvious I'm doing wrong, or can point me
> > > in the right direction with how to debug projection issues, I'd
> > > greatly
> > > appreciate it.
> > > -Camden Daily
