Display map with specified point in cen ter
    Eric Bridger
    eric at GOMOOS.ORG
    Thu Dec 16 06:46:08 PST 2004
On Thu, 2004-12-16 at 07:47, Miroslav Šulc wrote:
> Thank you, James,
> does anybody know whether this can also be done through php mapscript?
> Shanton, James A wrote:
> >Miroslav,
> >I'm doing it this way.
> >http://www.mydomain.com/mapserver/bin/mapserv.exe?map=D%3A%5CMAPS%5CGIS2%5Ct
> >hex.map&mapxy=" & rst("LONGITUDE") & "+" & rst("LATITUDE") &
> >"&layer=idogr&layer14=railroad&layer14=ortho&scale=5000&mapsize=600+500
Yes this can be done with Mapscript. Unfortunately I'm not sure of the
PHP syntax, but here is a Perl Mapscript example. The trick here is
getting an image object and doing the drawing yourself using
pointObj->draw().
my $map = new mapscript::mapObj("simple_points.map");
# create an image for drawing.
my $img = $map->draw();
my $layerObj = $map->getLayerByName('points');
my $point = new mapscript::pointObj();
$point->{x} = $longitude;
$point->{y} = $latitude;
my $label =  "The label";
$point->draw($map, $layerObj, $img, undef, $label);
# To display labels.
$map->drawLabelCache($img);
$img->save("/tmp/map.png");
############### Map file fragment
LAYER
  NAME "points"
  TYPE POINT
  STATUS ON
  TOLERANCE 10
  # Need fake template for querys to work
  TEMPLATE "bogus.html"
  CLASS
    NAME "buoy"
    STYLE
      SYMBOL "circle"
      SIZE 10
      COLOR 255 0 0
      OUTLINECOLOR 0 0 0
    END
    LABEL
      COLOR 255 0 0
      TYPE BITMAP
      SIZE MEDIUM
      POSITION AUTO
      PARTIALS FALSE
      BUFFER 2
    END # end of label
  END
  PROJECTION
    "proj=latlong"
  END
END
More information about the MapServer-users
