Problem with Oracle Spatial
Fernando Simon
fsimon at UNIVALI.BR
Sat Dec 18 15:33:25 EST 2004
The problem is not with oracle table. I believe that the problem
is with the MIGRATE procedure. After you import your data, did you
executed the "EXECUTE SDO_MIGRATE.TO_CURRENT('<your table>','<geom
column>');" procedure in sqlplus?
If you don't execute this procedure after import the data with
shp2sdo the mapserver don't draw any data from oracle.
Thanks.
Fernando Simon - simon at inf.univali.br
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada
http://g10.cttmar.univali.br
Citando Lorena Medellin <lorena_medellin at YAHOO.ES>:
> Hi,
> I have Oracle EE 9.2.0.1.0 with Oracle Spatial, I loaded a layer
> with shp2sdo to oracle spatial. The USER_SDO_GEOM_METADATA table is
> ok.
> Then I install mapserver4.4.0-oracle binary and my mapfile is:
> NAME MANIZALES
> STATUS ON
> SIZE 300 200
> EXTENT 1169230 1047365 1183658 1056453
> UNITS METERS
> IMAGECOLOR 255 255 255
> IMAGETYPE PNG
> LAYER
> NAME BARRIO
> TYPE POLYGON
> CONNECTIONTYPE oraclespatial
> CONNECTION "system/oracle at dbtitan"
> DATA "GEOMETRIE FROM (SELECT GEOMETRIE FROM BARRIO)"
> DUMP TRUE
> CLASS
> OUTLINECOLOR 0 0 0
> COLOR 0 128 128
> END
> END
> END
> and when I tried to connect by browser there is a problem,
> mapserver doesn't show me the image, I used mode map:
http://titan/cgi-bin/mapserv.exe?map=C:\apache\Apache2\htdocs\oracle\manizales.map&mode=map
> Please, help me!
> Regards
> Lorena
> Elsa Lorena Medellin V.
Univali - Webmail - http://webmail.univali.br
