Virtual Spatial Data crashing map
Mike Davis
mike.and.kerry at GMAIL.COM
Mon Dec 20 20:57:26 EST 2004
I am using the version of GDAL shiping with the windows binaries from
maptools. It is version 1.2.5.
I have been looking through various lists, searching for clues as to
why I can't access the data. I noticed the note about environmental
variables being set correctly, but we are using IIS not Apache.
I have placed the .ovf file at the shapepath to help keep things
simple, but still no-go. There must be some sort of environmental
limitation keeping mapserver from accessing the file...
On Thu, 16 Dec 2004 15:39:27 -0500, Frank Warmerdam
<fwarmerdam at gmail.com> wrote:
> On Thu, 16 Dec 2004 11:32:44 -0900, Mike Davis <mike.and.kerry at gmail.com> wrote:
> > I have been messing around with using x,y points in our Mapserver 4.2
> > sites via OGR's Virtual Spatial Data feature. The data is stored in
> > an Access database and I am using a working ODBC connection to get to
> > the data. In the .map file I have configured the CONNECTION as
> > follows:
> Mike,
> What version of GDAL are you using? Some recent versions had a crash
> triggering condition in the vrt handling code but GDAL 1.2.5 should be clean.
> If you are using something older please update to that.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
