Scale value output in MapServer CGI
Richard Greenwood
richard.greenwood at GMAIL.COM
Thu Dec 23 23:26:31 EST 2004
On Wed, 22 Dec 2004 13:08:49 -0500, Kralidis,Tom [Burlington]
<Tom.Kralidis at ec.gc.ca> wrote:
> Hi,
> Using MapServer CGI, I currently run the [scale] value through the
> JavaScript functions below:
> // fix scale values
> function fnxRoundNo(i) {
> var new_scale;
> new_scale = separate(Math.round(i/100)*100, ",");
> document.write("Scale 1: " + new_scale);
> function separate(input, separator) {
> var input2 = "" + input;
> var output = "";
> for (var i=0; i < input2.length; i++) {
> if (i != 0 && (input2.length - i) % 3 == 0) output += separator;
> output += input2.charAt(i);
> return output;
> So something like 226787247.360000 is output as: 1: 226,787,200 via:
> javascript:fnxRoundNo(226787247.360000);
> Is there a way to get this from the CGI itself without having to put
> through JavaScript?
Not that I know of.
> If no, does anyone think this would be a useful
> enhancement to MapServer CGI (i.e. addition of [scale_rounded] type
> template variable)?
Yes, seems like it would be useful. Like if you wanted to avoid
javascript. But I would think it should be a map file parameter. Why
are you thinking template variable?
Regards,
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
