Mapserver 4.4 CGI segfaults
Romolo Manfredini
romoloman at HOTMAIL.COM
Fri Dec 24 21:29:40 EST 2004
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, December 24, 2004 11:59 AM
Subject: [UMN_MAPSERVER-USERS] Mapserver 4.4 CGI segfaults
> Hi,
> I've downloaded and compiled Mapserver 4.4, and whilst the PHP module
> seems to work fine (PHP5 on Apache 2), the CGI program consistently
> segfaults.
> My configure arguments were:
> '--with-proj=/usr/local' '--with-geos=/usr/local/bin/geos-confi
> g' '--with-ogr=/usr/local/bin/gdal-config'
> '--with-gdal=/usr/local/bin/gdal-conf
> ig' '--with-postgis=yes' '--with-ming=/usr/lib/ming'
> '--with-httpd=/usr/sbin/apa
> che2' '--with-php=/usr/include/php'
> '--with-php-regex-dir=/var/tmp/portage/php-5
> .0.2-r1/work/php-5.0.2/regex'
I think that the problem is in using the php-regex library even for the cgi,
i have actually solved the problem with a double make process, one for the
cgi and one for the php/mapscript stuff.
I'm experiencing this problem in 4.4.0 and in 4.4.1.
Best Regards
Romolo Manfredini
