performance problem
Steve Lime
steve.lime at DNR.STATE.MN.US
Mon Dec 27 16:50:56 EST 2004
As I read this you're creating 4000 line features, each one point longer
than the first. So the first line contains 1 point (bad!), the second
line contains 2 points, the third 3 points. Are you sure that's what you
want? I can see why you have a bit of a performance issue. Shouldn't
adding the track to the shape and layer happen outside the for loop?
Like so:
# build the track
for($i=0;$i<count($pointlist);$i++){
$lat=$pointlist[$i][0];
$long=$pointlist[$i][1];
$pointObj->setXY($long,$lat);
$line->add($pointObj);
# create a feature from the track and add to feature
$shp = ms_newShapeObj(MS_SHAPE_LINE);
$shp->add($line);
if($TrackLayerObj->addFeature($shp) == -1){
echo "addFeature in lineLayer failed";
This would result in one 4000 point feature being added to the
'gpstrack' layer.
Steve
>>> joerg pfeiffer <superbla3000 at GMX.NET> 12/27/2004 10:57:44 AM >>>
hello,
I have a 4000 point track in mysql. I build my trackline with
$TrackLayerObj = $this->map->getLayerByName('gpstrack');
$pointObj = ms_newPointObj();
$line = ms_newLineObj();
$shp->add($line);
If I choose just a few trackpoints, it's no problem. But when I want
to
show all 4000, linux 'top' shows php-cgi running and running and then
I
get a blank browser site, due to timeout I guess.
Are 4000 points too much?
Any ideas?
Joerg
