Timeout with REQUIRES
Abe Gillespie
agillesp at VT.EDU
Mon Dec 27 17:41:24 EST 2004
Uh, no, that shouldn't be a problem. If it was, the whole map file
wouldn't parse correctly. That single quote just adds a "feet"
designation to the elevation measurement. In fact, if I remove the
"Buildings 0" layer completely, everything runs fine.
-Abe
On Dec 27, 2004, at 5:05 PM, Ethan Alpert wrote:
> Look at the TEXT label for the Flood Elevation layer.
> TEXT ([ELEVATION]')
> You're missing a '
> I've had all kinds of problems before when I miss a " or '
> -e
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> On
> Behalf Of Abe Gillespie
> Sent: Monday, December 27, 2004 3:22 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Timeout with REQUIRES
> I have two layers that look like this:
> LAYER
> NAME "Flood Zone"
> STATUS ON
> DATA "flood_zo"
> TYPE polygon
> MAXSCALE 300000
> UNITS FEET
> CLASS
> COLOR 68 126 171
> OUTLINECOLOR 11 57 92
> END
> GROUP "Layers"
> END
> LAYER
> NAME "Flood Elevation"
> STATUS ON
> DATA "flood_el"
> TYPE line
> UNITS FEET
> MAXSCALE 20000
> CLASS
> COLOR 68 155 255
> TEXT ([ELEVATION]')
> LABEL
> TYPE TRUETYPE
> FONT arial
> SIZE 8
> POSITION cc
> COLOR 0 0 0
> ANGLE auto
> MINFEATURESIZE 1
> END
> END
> REQUIRES "([Flood Zone] = 1)"
> END
> Notice the "REQUIRES" tag. These two layers cause no problems.
> However,
> I also have these two layers further in the map file:
> LAYER
> NAME "Buildings"
> STATUS ON
> DATA "bldg1"
> TYPE polygon
> MAXSCALE 15000
> UNITS FEET
> LABELITEM "ADDRESS"
> LABELCACHE on
> LABELMAXSCALE 6000
> CLASS
> COLOR 220 149 146
> OUTLINECOLOR 190 95 96
> LABEL
> MINFEATURESIZE 12
> TYPE truetype
> FONT arial
> ANTIALIAS true
> ANGLE auto
> POSITION cc
> COLOR 0 0 0
> OUTLINECOLOR 255 255 255
> BUFFER 3
> SIZE 8
> END
> END
> TOLERANCE 3
> TEMPLATE "x"
> METADATA
> search_field "FULLADDR"
> search_fields "FULLADDR"
> search_aliases "Address"
> END
> GROUP "Layers"
> END
> LAYER
> NAME "Buildings 0"
> STATUS ON
> DATA "bldg0"
> TYPE polygon
> MAXSCALE 15000
> UNITS FEET
> CLASS
> COLOR 168 168 168
> OUTLINECOLOR 97 97 97
> END
> REQUIRES "([Buildings] = 1)"
> END
> With the "Buildings 0" layer, if I include the "REQUIRES" tag MapServer
> will timeout. If I remove the "REQUIRES" tag everything runs smoothly.
> I'm using PHP Mapscript 4.4.1. Before I upgraded (I think it was
> Mapscript 4.0) this worked fine. So something has changed between then
> and now with the "REQUIRES" algorithm.
> Any ideas?
> Thanks.
> -Abe
