Mapscript issues... {Scanned}
Jeff Portwine
jdport at VERITIME.COM
Tue Dec 28 11:20:07 EST 2004
Here is the output of ldd php_mapscript.so.
I'm not entirely sure what I'm looking for here. The only thing strange
that jumps out at me is that I installed the gd libs in /usr/local/lib and
this is showing gd libraries in /usr/local/nushpere/lib. Other than that
I can't really tell that there is anything missing or wrong.
I've tried running some of the other examples besides hello.phtml and I get
an error that says "loadProjection(): Projection support is not available.
It's very confusing... I wish I could find a beginners tutorial that took me
through the basics of the mapserver.. let me know where to put files, etc.
Instead of looking around in various places for examples when I don't even
know where exactly I should be putting the example files.
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x400a7000)
libz.so.1 => /usr/lib/libz.so.1 (0x400f8000)
libiconv.so.2 => /usr/lib/libiconv.so.2 (0x40106000)
libgd.so.2 => /usr/local/nusphere/lib/libgd.so.2 (0x401dd000)
libm.so.6 => /lib/tls/libm.so.6 (0x40216000)
libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x40238000)
libc.so.6 => /lib/tls/libc.so.6 (0x42000000)
libjpeg.so.62 => /usr/local/nusphere/lib/libjpeg.so.62 (0x402ec000)
libpng12.so.0 => /usr/local/nusphere/lib/libpng12.so.0 (0x4030e000)
libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40336000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
Thanks for any help, it is appreciated.
-Jeff
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Tuesday, December 28, 2004 1:04 PM
Subject: Re: [UMN_MAPSERVER-USERS] Mapscript issues... {Scanned}
> Hi,
> Check your php_mapscript.so using ldd
> You will get a list of loadable libraries which the mapscript depends on.
> Probably the libgd missing or the version is old or the directory of
> the so file is not in the /etc/ld.so.conf file, see man ldconfig.
> I hope it helps you.
> Bye
> Zoltan
