Mapscript issues... {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Tue Dec 28 17:32:54 EST 2004
Did you build mapserv and mapscript from source of use an RPM?
Is the /usr/local/nushpere/lib in the /etc/ld.so.conf?
Is the libgd.so.2 in that directory?
If not add it to the end and run ldconfig to read the new configuration.
Was the mapserv built/configured --with-gd and --with-proj?
You may had better to move libgd to usual place /usr/lib or
/usr/local/lib.
If you get error about projection than probably you should load
php_proj.so
dl("php_proj.so");
I only guess ...
Bye
Zoltan
On Tue, 28 Dec 2004, Jeff Portwine wrote:
> Here is the output of ldd php_mapscript.so.
> I'm not entirely sure what I'm looking for here. The only thing strange
> that jumps out at me is that I installed the gd libs in /usr/local/lib and
> this is showing gd libraries in /usr/local/nushpere/lib. Other than that
> I can't really tell that there is anything missing or wrong.
> I've tried running some of the other examples besides hello.phtml and I get
> an error that says "loadProjection(): Projection support is not available.
> It's very confusing... I wish I could find a beginners tutorial that took me
> through the basics of the mapserver.. let me know where to put files, etc.
> Instead of looking around in various places for examples when I don't even
> know where exactly I should be putting the example files.
> libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x400a7000)
> libz.so.1 => /usr/lib/libz.so.1 (0x400f8000)
> libiconv.so.2 => /usr/lib/libiconv.so.2 (0x40106000)
> libgd.so.2 => /usr/local/nusphere/lib/libgd.so.2 (0x401dd000)
> libm.so.6 => /lib/tls/libm.so.6 (0x40216000)
> libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x40238000)
> libc.so.6 => /lib/tls/libc.so.6 (0x42000000)
> libjpeg.so.62 => /usr/local/nusphere/lib/libjpeg.so.62 (0x402ec000)
> libpng12.so.0 => /usr/local/nusphere/lib/libpng12.so.0 (0x4030e000)
> libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40336000)
> /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
> Thanks for any help, it is appreciated.
> -Jeff
> ----- Original Message -----
> From: "Siki Zoltan" <siki at AGT.BME.HU>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Tuesday, December 28, 2004 1:04 PM
> Subject: Re: [UMN_MAPSERVER-USERS] Mapscript issues... {Scanned}
> > Hi,
> > Check your php_mapscript.so using ldd
> > You will get a list of loadable libraries which the mapscript depends on.
> > Probably the libgd missing or the version is old or the directory of
> > the so file is not in the /etc/ld.so.conf file, see man ldconfig.
> > I hope it helps you.
> > Bye
> > Zoltan
