Timeout with REQUIRES
Abe Gillespie
agillesp at VT.EDU
Tue Dec 28 16:54:29 EST 2004
Comments are inline.
-Abe
On Dec 27, 2004, at 7:45 PM, Steve Lime wrote:
> Abe's right the single quote isn't a problem. The requires directive
> was
> mostly broken in 4.2 and probably 4.0. There were changes made in
> portions of the code that made requires basically useless. The problem
> was only found and fixed right before 4.4 was released.
> I don't see anything obvious but let's try a couple of things and see
> if
> they help.
> 1) You don't need ()'s nor equality tests. So
> REQUIRES "([Buildings] = 1)" should be REQUIRES "[Buildings]" and
Didn't change anything - still timing out.
> REQUIRES "([Flood Zone] = 1)" should be REQUIRES "[Flood Zone]"
Didn't change anything - continued to work w/o problems.
> 2) Try renaming "Buildings 0" to "Buildings_0". I'm thinking there may
> be an issue with some string comparisons someplace.
> Please try these one at a time and let me know how it goes.
> Steve
>>>> Abe Gillespie <agillesp at VT.EDU> 12/27/04 4:41 PM >>>
> Uh, no, that shouldn't be a problem. If it was, the whole map file
> wouldn't parse correctly. That single quote just adds a "feet"
> designation to the elevation measurement. In fact, if I remove the
> "Buildings 0" layer completely, everything runs fine.
> -Abe
> On Dec 27, 2004, at 5:05 PM, Ethan Alpert wrote:
>> Look at the TEXT label for the Flood Elevation layer.
>> TEXT ([ELEVATION]')
>> You're missing a '
>> I've had all kinds of problems before when I miss a " or '
>> -e
>> -----Original Message-----
>> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
>> On
>> Behalf Of Abe Gillespie
>> Sent: Monday, December 27, 2004 3:22 PM
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: [UMN_MAPSERVER-USERS] Timeout with REQUIRES
>> I have two layers that look like this:
>> LAYER
>> NAME "Flood Zone"
>> STATUS ON
>> DATA "flood_zo"
>> TYPE polygon
>> MAXSCALE 300000
>> UNITS FEET
>> CLASS
>> COLOR 68 126 171
>> OUTLINECOLOR 11 57 92
>> END
>> GROUP "Layers"
>> END
>> LAYER
>> NAME "Flood Elevation"
>> STATUS ON
>> DATA "flood_el"
>> TYPE line
>> UNITS FEET
>> MAXSCALE 20000
>> CLASS
>> COLOR 68 155 255
>> TEXT ([ELEVATION]')
>> LABEL
>> TYPE TRUETYPE
>> FONT arial
>> SIZE 8
>> POSITION cc
>> COLOR 0 0 0
>> ANGLE auto
>> MINFEATURESIZE 1
>> END
>> END
>> END
>> Notice the "REQUIRES" tag. These two layers cause no problems.
>> However,
>> I also have these two layers further in the map file:
>> LAYER
>> NAME "Buildings"
>> STATUS ON
>> DATA "bldg1"
>> TYPE polygon
>> MAXSCALE 15000
>> UNITS FEET
>> LABELITEM "ADDRESS"
>> LABELCACHE on
>> LABELMAXSCALE 6000
>> CLASS
>> COLOR 220 149 146
>> OUTLINECOLOR 190 95 96
>> LABEL
>> MINFEATURESIZE 12
>> TYPE truetype
>> FONT arial
>> ANTIALIAS true
>> ANGLE auto
>> POSITION cc
>> COLOR 0 0 0
>> OUTLINECOLOR 255 255 255
>> BUFFER 3
>> SIZE 8
>> END
>> END
>> TOLERANCE 3
>> TEMPLATE "x"
>> METADATA
>> search_field "FULLADDR"
>> search_fields "FULLADDR"
>> search_aliases "Address"
>> END
>> GROUP "Layers"
>> END
>> LAYER
>> NAME "Buildings 0"
>> STATUS ON
>> DATA "bldg0"
>> TYPE polygon
>> MAXSCALE 15000
>> UNITS FEET
>> CLASS
>> COLOR 168 168 168
>> OUTLINECOLOR 97 97 97
>> END
>> END
>> With the "Buildings 0" layer, if I include the "REQUIRES" tag
> MapServer
>> will timeout. If I remove the "REQUIRES" tag everything runs
> smoothly.
>> I'm using PHP Mapscript 4.4.1. Before I upgraded (I think it was
>> Mapscript 4.0) this worked fine. So something has changed between
> then
>> and now with the "REQUIRES" algorithm.
>> Any ideas?
>> Thanks.
>> -Abe
