[non-spatial]-mysql: point data source
Bart van den Eijnden
bartvde at XS4ALL.NL
Wed Dec 29 04:42:21 EST 2004
Hi Dylan,
just a thought, you could also use OGR Virtual Spatial Data (and then
group your layers together in the MAP file).
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData
Best regards,
Bart
> Greetings everyone!
> I have been using mapserver for quite some time with shapefiles, and am
> quite pleased with its flexibility.
> I was wondering if it would be possible to add point data records, stored
> in a MySQL data base, to a map that was created by shapefiles. The records
> in mysql would be formatted as follows:
> point_id, x, y, attribute_1, ...
> this is not in the openGIS format that the myGIS connector is using, and
> so I wonder if it is even possible to get a 'list' of points like this
> into a mapserver application.
> I would like to use PHPmapscript, but i have problems running PHP as a CGI
> as opposed to the more traditional Apache DSO (maybe this problem has been
> solved...)
> any ideas would be greatly appreciated.
> Dylan
