GeoTIFF display problem
R. Paul Warriner
paul at WARRINER.US
Wed Dec 29 12:35:36 EST 2004
I am having problems displaying the
following GeoTIFF file.
I was able to create a shape file index
from these tif files, and it displays
fine, but the map file below will not
display the image.
Hoping for any help.
Regards, Paul
gdalinfo:
w_10950988_12_07200_col_2002.tif
Driver: GTiff/GeoTIFF
Size is 3000, 2000
Coordinate System is `'
Origin = (1095000.000000,990000.000000)
Pixel Size = (1.00000000,-1.00000000)
Corner Coordinates:
Upper Left ( 1095000.000, 990000.000)
Lower Left ( 1095000.000, 988000.000)
Upper Right ( 1098000.000, 990000.000)
Lower Right ( 1098000.000, 988000.000)
Center ( 1096500.000, 989000.000)
Band 1 Block=3000x2 Type=Byte,
ColorInterp=Red
Band 2 Block=3000x2 Type=Byte,
ColorInterp=Green
Band 3 Block=3000x2 Type=Byte,
ColorInterp=Blue
START MAP FILE----------------
NAME "OP2004_"
SIZE 800 800
STATUS ON
EXTENT 998800.750 888365.9375
1194305.375 1129057.375
UNITS FEET
TEMPLATEPATTERN "printable.html|loader.html"
SHAPEPATH "/opmap/mapsurfer/shapes"
IMAGETYPE png
OUTPUTFORMAT
NAME GTiff
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE RGBA
EXTENSION "tif"
END
WEB
TEMPLATE "printable.html"
EMPTY "/opmap/mapsurfer/info.html"
# path relative to the webserver
document root
IMAGEPATH
"/var/www/htdocs/opmap/mapsurfer/tmp/"
IMAGEURL "/opmap/mapsurfer/tmp/"
END
LAYER
NAME "w_10950988_12_07200_col_2002"
DATA
"shapes/geotiff/w_10950988_12_07200_col_2002.tif"
STATUS ON
TYPE RASTER
END
LAYER
NAME "geotiff_index"
DATA "shapes/geotiff_index.shp"
STATUS ON
TYPE POLYGON
CLASS
STYLE
OUTLINECOLOR 0 0 0
COLOR -1 -1 -1
END
END
END
-----cut PostGIS layers
