Hi Frank,
thanks. I have run into a problem runtime (in normal cgi mode, not fastcgi
mode yet) not compile time.
What I did was:
-download fcgi-2.4.0
-nmake /f makefile.nt CFG=Debug
-put your settings into the nmake.opt file
Everything compiles perfectly, for running mapserv.exe I now needed two
MSVC dll's: MSVCP60D.DLL and MSVCRTD.DLL (probably because of the debug
mode of fcgi).
When I try to run a WMS GetCapabilities, my capabilities are mucked up. If
I comment the FASTCGI support in the makefile, and recompile, the WMS
GetCapabilities work as expected.
This is the mucked up part (the last line should be where UserLayer= ends):
<UserDefinedSymbolization SupportSLD="1" UserLayer= <Style>
<Name>default</Name>
<Title>default</Title>
</Style>
"0" UserStyle="1" RemoteWFS="0"/>
Do you have any idea what's going on here?
Best regards,
Bart
On Thu, 30 Dec 2004 20:53:19 -0500, Frank Warmerdam <fwarmerdam at GMAIL.COM>
wrote:
> On Tue, 28 Dec 2004 17:16:27 +0100, Bart van den Eijnden
> <bartvde at xs4all.nl> wrote:
>> Hi list,
>> has anybody compiled Mapserver in fastcgi mode on Windows?
>> The current makefiles don't have options for enabling FASTCGI (the
>> configure file has though for Unix/Linux), so I am looking for what to
>> add
>> to the makefile.vc or nmake.opt in order to get a Mapserver FastCGI.
> Bart,
> Sorry about that. I neglected to get the FastCGI stuff into
> 4.4 in time. You might want to just use MapServer 4.5 (aka dev)
> which does have stubs in the nmake.opt for FastCGI support.
> It looks something like:
> # FastCGI Support
> # Uncomment, and update accordingly.
> #FCGIDIR=C:\projects\fcgi-2.4.0
> #FCGILIB=$(FCGIDIR)\libfcgi\Debug\libfcgi.lib
> #FCGIINC=-I$(FCGIDIR)\include
> #FCGIDEF=-DUSE_FASTCGI
> EXTERNAL_LIBS=$(GD_LIBS) $(TIFF_LIB) $(JPEG_LIB) \
> $(PROJ_LIB) $(OGR_LIB) $(GDAL_LIB)\
> $(CURL_LIB) $(MING_LIB) $(PDF_LIB) \
> $(WINSOCK_LIB) $(POSTGIS_LIB) $(IMGGEN_LIB) $(ERR_LIB) \
> $(ORACLE_LIB) $(SDE_LIB) $(ICONV_LIB) $(FCGILIB)
> NCLUDES=$(GD_INC) $(TIFF_INC) $(JPEG_INC) \
> $(PROJ_INC) $(REGEX_INC) $(GDAL_INC) $(OGR_INC) \
> $(CURL_INC) $(MING_INC) $(PDF_INC) $(POSTGIS_INC) \
> $(IMGGEN_INC) $(ERR_INC) $(ORACLE_INC) $(SDE_INC)\
> $(ICONV_INC) $(FCGIINC)
> MS_DEFS = $(REGEX_OPT) $(STRINGS) $(POSTGIS) -DWIN32 -D_WIN32 \
> $(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS) \
> $(WMSCLIENT) $(MING) $(IGNORE_MISSING_DATA)
> $(NEED_NONBLOCKING_STDERR) $(ENABLE_STDERR_DEBUG) \
> $(GDAL) $(FCGIDEF) \
> $(WFS) $(WFSCLIENT) $(WCS) $(PDF) $(EGIS) \
> $(USE_GD_ANTIALIAS) $(ORACLE) $(MING_VERSION) $(SDE_OPT) $(ICONV)
> Let me know if you run into specific problems. My next FWTools
> build of MapServer for win32 will come shipped with FastCGI
> enabled.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
