[Mapserver-users] Mapserver 401: Reference image bounding box
Till Adams
adams at terrestris.de
Tue Jan 6 03:34:43 EST 2004
Julien,
I had this problem before - your image used for the reference map might
have a higher resolution than the defined box in your clinet - e.g. the
image has 600 x 400 pix and in your client you defined the reference map
to have 140 x 100 pix: Mapserver scales the image down to 150 x 100 pix
(also leading to performance loss) and with it the (red) bounding box,
which has 1 pixel linewidth.
Cheers,
Till
Julien, Heryk schrieb:
> Hi,
> Anyone else having trouble or found a solution to the reference image
> "bounding box" not being drawn?
> I selected a red bounding box (outlinecolor 255 0 0) in my mapfile but it is
> not showing up on the reference image!
> I'm using Mapserver 401.
> Héryk
> NRCan
>> -----Message d'origine-----
>>De : Julien, Heryk
>>Envoyé : Thursday, December 18, 2003 2:28 PM
>>À : 'mapserver-users at lists.gis.umn.edu'
>>Objet : reference image bounding box
>>Hi,
>>I'm having trouble with my reference image bounding box. The reference
>>image appears and I can navigate in my map by clicking in the reference
>>image however the bounding box doesn't display in the reference image.
>>Anyone had that trouble before?
>>Mapfile:
>># Start of reference map
>>REFERENCE
>> COLOR -1 -1 -1
>> EXTENT 493163 4857827 2100223 5910452
>> STATUS ON
>> OUTLINECOLOR 255 0 0
>> SIZE 175 117
>> IMAGE "..\data\raster\refQcMaritimesUTM83Z18.gif"
>>END #REFERENCE
>>Héryk
>>NRCan
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
NEU +++ NEU +++ NEU +++ NEU
AveiN! ist Open Source
Lizensiert unter der GNU GPL
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
