[Mapserver-users] easy question
Steve Lime
steve.lime at dnr.state.mn.us
Tue Jan 6 12:46:05 EST 2004
Are you explicity requesting the testpoint layer? If using the CGI all
layers are off unless declared as DEFAULT or explicitly requested (i.e.
layer=testpoint). Also, you need a symbol to use a class size, otherwise
all you'll get is a single green pixel. Try adding:
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
to the map file and add:
SYMBOL 'circle'
to the testpoint class definition.
Steve
>>> "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br> 1/6/2004 11:02:49 AM
thanks eric, i tried it but didnt work, here is my map file:
NAME FIRSTMAP
SIZE 400 300
STATUS ON
EXTENT 598047.223047 781652.733880 619791.428883 812944.406142
UNITS METERS
IMAGECOLOR 255 255 255
WEB
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
LOG "/tmp/gmap.log"
END
LAYER
NAME testpoint
STATUS ON
TYPE POINT
CLASS
COLOR 200 255 0
SIZE 10
END
FEATURE
POINTS 618579.06 806912.68 END
END
END
END
i received blank screen and not one point (or any green symbol),
anyone
knows why?
Hugo Rodrigues
Analista/Consultor
SSSS - Prodabel
----- Original Message -----
To: "Hugo Nathaniel Rodrigues" <hugo at pbh.gov.br>
Cc: "Mapserver List" <mapserver-users at lists.gis.umn.edu>
Sent: Monday, January 05, 2004 6:21 PM
Subject: Re: [Mapserver-users] easy question
> On Mon, 2004-01-05 at 14:23, Hugo Nathaniel Rodrigues wrote:
> > i have this coordinates:
> > x 618579,06
> > y 806912,68
> > (meters)
> > what i need to put in my map file (using gmap75.map example) to
show a
point (or symbol or anything) in this point of the map?
> > this is my extent:
> You'll want to use the LAYER FEATURE tag in your map file. This
works
> for mapserver 3.6.
> LAYER
> NAME "test_point"
> STATUS DEFAULT
> TYPE POINT
> CLASS
> COLOR 0 0 0
> SIZE 10
> END
> FEATURE
> END
> END
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
