[Mapserver-users] WFS support
Amit S BEHERE
abehere at cs.ucsd.edu
Tue Jan 6 18:19:13 EST 2004
There is not a win32 binary for Mapserver 4.0.1 (with WFS support). Is
there a way I can use the the source for mapserver 4.0.1 to build it for
windows. If there is, is there any documentation available regarding the
same. When might the binary for Mapserver 4.0.1 be released ?
Thanks,
Amit Behere.
UCSD.
"Technology doesn't make your life more difficult or easy, it just changes
the rules"......Vishwanathan Anand
On Tue, 6 Jan 2004, Normand Savard wrote:
> Hi,
> See answers below.
> Norm
> Kralidis,Tom [Burlington] wrote:
> >>-----Original Message-----
> >>From: Amit S BEHERE [mailto:abehere at cs.ucsd.edu]
> >>Sent: Monday, January 05, 2004 7:22 PM
> >>To: mapserver-users at lists.gis.umn.edu
> >>Subject: [Mapserver-users] WFS support
> >>Hi all,
> >>I do not seem to be able to filter my queries (WFS queries)
> >>correctly. I read in the documentation that only BBOX filter
> >>is supposed to work for WFS queries. Now does that mean that
> >>only the BBOX filter will work among the spatial filters
> >>(filters could be attribute filters or spatial filters) or
> >>its BBOX filter alone without any other attribute or spatial filters.
> Only the BBOX spatial filter is supported but he BBOX can be used in
> combinatiion with other filter types.
> Example:
> http://localhost/cgi-bin/mapserv-4.0?map=/home/httpd/html/prototypes/ec/msc/
> config.map&version=1.0.0&service=WFS&request=GetFeature&typename=stn_info&
> filter=<filter><AND><BBOX><PropertyName>Name</PropertyName><Box+srsName='EPSG:42304'>
> <coordinates>201000,-7300+410396,67400</coordinates></Box></BBOX><PropertyIsEqualTo>
> <PropertyName>NAME</PropertyName><Literal>Digby</Literal></PropertyIsEqualTo></AND></filter>
> >In MapServer OGC:WFS (v4.0), BBOX works like this:
> >config.map&version=1.0.0&service=WFS&request=GetFeature&typename=stn_info&bb
> >ox=-120,50,-118,51
> >As for Filter, the forthcoming release of MapServer will support Filter
> >Encoding (is it already in CVS?), so you should be able to pull off queries
> >like:
> The filter encoding support is in MapServer 4.1 cvs.
> >ox=-120,50,-118,51&filter=<Filter><PropertyIsEqualTo><PropertyName>Street</P
> >ropertyName><Literal>myhouseaddr%20blvd</Literal></PropertyIsEqualTo></Filte
> >r>
> >Now, I'm not sure whether spatial filtering will still be supported by the
> >BBOX parameter, or as a GML element in Filter, or both. Perhaps the DM
> >Solutions folks can clarify to what extent Filter will be supported.
> The BBOX parameter is mutually exclusive with FEATUREID and FILTER as
> stated in the WFS specifications (see 13.7.3.1). So the BBOX is
> supported as a GML element.
> >Thanks
> >..Tom
> >Tom Kralidis
> >Systems Scientist
> >Environment Canada
> >Tel: +01-905-336-4409
> >http://www.ec.gc.ca/cise/
> >>So bottom line is can I do something like the following
> >>query, "Return me trees only on the street matching the
> >>property Street=myhouseaddr blvd" using filters. If I can it
> >>means I am going wrong somewhere with my query.
> >>Amit Behere.
> >>UCSD.
> >>"Technology won't make your life more difficult or easy, it
> >>just changes the rules"......Vishwanathan Anand
> >>_______________________________________________
> >>Mapserver-users mailing list
> >>Mapserver-users at lists.gis.umn.edu
> >>http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
> >http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
