[Mapserver-users] WFS support
Amit S BEHERE
abehere at cs.ucsd.edu
Tue Jan 6 19:14:28 EST 2004
w.r.t the question below
Am sorry for asking a wrong question. I didnot mean 4.0.1 but version 4.1
(the nightly build).
I have downloaded and compiled the nightly build for 4.1. However I would need to
get it working on a Windows machine as well. So again, repeating the
question. For the 4.1 build, is there a way I could compile it for Windows
(is there documentation regarding the same).
If I cannot do that, when might the 4.1 binary for Windows be released ?
Thanks,
Amit Behere [UCSD]
"Technology doesn't make your life more difficult or easy, it just changes
the rules"......Vishwanathan Anand
On Tue, 6 Jan 2004, Yewondwossen Assefa wrote:
> You can download the binaries at
> http://www.maptools.org/php_mapscript/index.phtml?page=downloads.html.
> Later,
> Amit S BEHERE wrote:
> > Hi,
> > There is not a win32 binary for Mapserver 4.0.1 (with WFS support). Is
> > there a way I can use the the source for mapserver 4.0.1 to build it for
> > windows. If there is, is there any documentation available regarding the
> > same. When might the binary for Mapserver 4.0.1 be released ?
> > Thanks,
> > Amit Behere.
> > UCSD.
> > On Tue, 6 Jan 2004, Normand Savard wrote:
> >>Hi,
> >>See answers below.
> >>Norm
> >>Kralidis,Tom [Burlington] wrote:
> >>>>-----Original Message-----
> >>>>From: Amit S BEHERE [mailto:abehere at cs.ucsd.edu]
> >>>>Sent: Monday, January 05, 2004 7:22 PM
> >>>>To: mapserver-users at lists.gis.umn.edu
> >>>>Subject: [Mapserver-users] WFS support
> >>>>Hi all,
> >>>>I do not seem to be able to filter my queries (WFS queries)
> >>>>correctly. I read in the documentation that only BBOX filter
> >>>>is supposed to work for WFS queries. Now does that mean that
> >>>>only the BBOX filter will work among the spatial filters
> >>>>(filters could be attribute filters or spatial filters) or
> >>>>its BBOX filter alone without any other attribute or spatial filters.
> >>Only the BBOX spatial filter is supported but he BBOX can be used in
> >>combinatiion with other filter types.
> >>Example:
> >>http://localhost/cgi-bin/mapserv-4.0?map=/home/httpd/html/prototypes/ec/msc/
> >>config.map&version=1.0.0&service=WFS&request=GetFeature&typename=stn_info&
> >>filter=<filter><AND><BBOX><PropertyName>Name</PropertyName><Box+srsName='EPSG:42304'>
> >><coordinates>201000,-7300+410396,67400</coordinates></Box></BBOX><PropertyIsEqualTo>
> >><PropertyName>NAME</PropertyName><Literal>Digby</Literal></PropertyIsEqualTo></AND></filter>
> >>>In MapServer OGC:WFS (v4.0), BBOX works like this:
> >>>config.map&version=1.0.0&service=WFS&request=GetFeature&typename=stn_info&bb
> >>>ox=-120,50,-118,51
> >>>As for Filter, the forthcoming release of MapServer will support Filter
> >>>Encoding (is it already in CVS?), so you should be able to pull off queries
> >>>like:
> >>The filter encoding support is in MapServer 4.1 cvs.
> >>>ox=-120,50,-118,51&filter=<Filter><PropertyIsEqualTo><PropertyName>Street</P
> >>>ropertyName><Literal>myhouseaddr%20blvd</Literal></PropertyIsEqualTo></Filte
> >>>r>
> >>>Now, I'm not sure whether spatial filtering will still be supported by the
> >>>BBOX parameter, or as a GML element in Filter, or both. Perhaps the DM
> >>>Solutions folks can clarify to what extent Filter will be supported.
> >>The BBOX parameter is mutually exclusive with FEATUREID and FILTER as
> >>stated in the WFS specifications (see 13.7.3.1). So the BBOX is
> >>supported as a GML element.
> >>>Thanks
> >>>..Tom
> >>>Tom Kralidis
> >>>Systems Scientist
> >>>Environment Canada
> >>>Tel: +01-905-336-4409
> >>>http://www.ec.gc.ca/cise/
> >>>>So bottom line is can I do something like the following
> >>>>query, "Return me trees only on the street matching the
> >>>>property Street=myhouseaddr blvd" using filters. If I can it
> >>>>means I am going wrong somewhere with my query.
> >>>>Amit Behere.
> >>>>UCSD.
> >>>>"Technology won't make your life more difficult or easy, it
> >>>>just changes the rules"......Vishwanathan Anand
> >>>>_______________________________________________
> >>>>Mapserver-users mailing list
> >>>>Mapserver-users at lists.gis.umn.edu
> >>>>http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
> >>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
