[Mapserver-users] saveImage error
Sean Gillies
sgillies at frii.com
Tue Jan 6 21:38:01 EST 2004
On Jan 6, 2004, at 4:05 PM, WILHITE JASON W wrote:
> I keep getting the following error when I try and run a very simple
> perl script using mapserver. The following is the debug statements
> along with the error message.
> Hello Starting test!
> DEBUG:::: Prep returned mapscript::imageObj=HASH(0x8457140)
> DEBUG:::: Draw returned mapscript::imageObj=HASH(0x8457140)
> DEBUG:::: ./rawMSTest.png, , 1
> Can't call method "saveImage" on an undefined value at rawMSTest.pl
> line 129.
> Here is the code snippet in question.
> #!/usr/sbin/perl
> use GD;
> use CGI;
> use POSIX;
> use strict;
> use mapscript;
> use Getopt::Long;
> #=================================== MAIN
> print "\nHello Starting test!\n";
> my $mapFileName = "./simpleGauge.map";
> my $pngFileName = "./rawMSTest.png";
> my $showPNG = 0;
> my ( $xMin, $xMax, $yMin, $yMax ) = (-112.39, -111.39, 33.20, 33.62);
> my $bgMap = new mapscript::mapObj( $mapFileName );
> $bgMap->{width} = 600;
> $bgMap->{height} = 600;
> my $imgPrep = $bgMap->prepareImage();
> print "\tDEBUG:::: Prep returned $imgPrep\n";
> my $imageObj = $bgMap->draw();
> print "\tDEBUG:::: Draw returned $imgPrep\n";
> `rm -f $pngFileName`;
> print "\tDEBUG:::: $pngFileName, $mapscript::MS_PNG,
> $bgMap->{transparent}\n";
> my $image_url = $imageObj->saveImage( $pngFileName,
> $mapscript::MS_PNG, $bgMap->{transparent}, 1, 95 ); <------Line where
> it is dying
> print "\tDEBUG:::: Save returned $image_url\n";
> if ($showPNG) {
> print "\nee'ing image file $pngFileName\n";
> `ee $pngFileName`;
> print "\nAll done!\n";
> Am I missing something incredibly obvious? This worked on Mapserver
> 3.6.4 but when I upgrade to mapserver 4.0.1 it blows up.
> Any ideas?
> Thanks,
> -Jason
Jason,
There is no imageObj::saveImage -- it's 'save' and you no longer need
to specify output format parameters because these are no held in the
imageObj instance. Check out the online docs for more details.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
