[Mapserver-users] WMS BBOX vs. Actual Bounds
Steve Lime
steve.lime at dnr.state.mn.us
Wed Jan 7 15:42:32 EST 2004
This is a MIME message. If you are reading this text, you may want to
consider changing to a mail reader or gateway that understands how to
properly handle MIME multipart messages.
--=__PartECB22228.1__=
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: 7bit
Content-Disposition: inline
There's no way with pure WMS (that I know of) to get the computed bounds
back other than by precomputing them to perfectly fit your requested
image size. I've done that with a java digitizing client that took WMS
images from MapServer and overlayed information from a seperate SDE/Java
application. Worked fine. I've attached the simple map geometry class I
used in that case, look at the fit method.
Regarding bounds computation. MapServer gaurantees that the requested
extent will fit in the image, so one of the dimensions will remain fixed
while the other is expanded as necessary. The decision as to which to
expand is based on how the extent is oriented (think portrait vs
landscape) relative to the "shape" of the image. The idea is to minimize
stuff outside the extent.
Steve
Stephen Lime
Data & Applications Manager
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
>>> John Gorkos <jgorkos at lenexa.sema.slb.com> 1/7/2004 12:20:20 PM >>>
Howdy-
My programming team is up against a hard deadline, and we're
stymied.
Basic project is this: use a WMS mapserver to feed a java applet a
base map,
and then connect (via TCP) to a real-time management system that feeds
us
status of devices across the planet, coded by lat/long and a status
code.
These then get overlayed on top of the base map on a "glass pane" that
can be
changed without redrawing the base. The result is little winkin',
blinkin'
lights on top of a map that show (in our case) whether or not
electricity is
on in various places across the US.
The problem is that when we send a BBOX request to the mapserver from
the
java applet, we don't get back a map with the exact coordinates we
asked for.
That's OK, I realize that mapserver gets as close as it can given the
size, but I've GOT to know what the real boundaries are so I can
overlay my
status dots on top. How do I get this information back from the
mapserver?
On a related thread, how does the mapserver decide what the real
boundaries
are, when given when the bounds requested don't match the aspect ratio
of the
returned image?
John Gorkos
SchlumbergerSema/Atos-Origin
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: application/octet-stream; name="MapGeometry.java"
Content-Transfer-Encoding: base64
Content-Disposition: attachment; filename="MapGeometry.java"
aW1wb3J0IGphdmEuYXd0LkRpbWVuc2lvbjsKCnB1YmxpYyBjbGFzcyBNYXBHZW9tZXRyeSB7CiAg
ZG91YmxlIG1pbngsIG1pbnksIG1heHgsIG1heHk7CiAgZG91YmxlIGNlbGxzaXplOwogIERpbWVu
c2lvbiBzaXplOwoKICBwdWJsaWMgTWFwR2VvbWV0cnkoZG91YmxlIHgxLCBkb3VibGUgeTEsIGRv
dWJsZSB4MiwgZG91YmxlIHkyLCBEaW1lbnNpb24gc2l6ZSkgewogICAgdGhpcy5zaXplID0gc2l6
ZTsKCiAgICB0aGlzLm1pbnggPSBNYXRoLm1pbih4MSwgeDIpOwogICAgdGhpcy5taW55ID0gTWF0
aC5taW4oeTEsIHkyKTsKICAgIHRoaXMubWF4eCA9IE1hdGgubWF4KHgxLCB4Mik7CiAgICB0aGlz
Lm1heHkgPSBNYXRoLm1heCh5MSwgeTIpOwoKICAgIHRoaXMuZml0KCk7CiAgfQoKICBwdWJsaWMg
dm9pZCBwb2ludFpvb20oZG91YmxlIHgsIGRvdWJsZSB5LCBkb3VibGUgem9vbSkgewogICAgZG91
YmxlIGR4LCBkeTsKICAgIGRvdWJsZSBteCwgbXk7CgogICAgZHggPSB0aGlzLm1heHggLSB0aGlz
Lm1pbng7CiAgICBkeSA9IHRoaXMubWF4eSAtIHRoaXMubWlueTsKICAgIG14ID0gdGhpcy5taW54
ICsgdGhpcy5jZWxsc2l6ZSp4OyAvLyBjb252ZXJ0ICpjbGljayogdG8gbWFwIGNvb3JkaW5hdGVz
CiAgICBteSA9IHRoaXMubWF4eSAtIHRoaXMuY2VsbHNpemUqeTsKCiAgICB0aGlzLm1pbnggPSBt
eCAtIC41KihkeC96b29tKTsKICAgIHRoaXMubWlueSA9IG15IC0gLjUqKGR5L3pvb20pOwogICAg
dGhpcy5tYXh4ID0gbXggKyAuNSooZHgvem9vbSk7CiAgICB0aGlzLm1heHkgPSBteSArIC41Kihk
eS96b29tKTsgCgogICAgdGhpcy5maXQoKTsKICB9CgogIHB1YmxpYyB2b2lkIHBvaW50Wm9vbShk
b3VibGUgeCwgZG91YmxlIHksIGRvdWJsZSB6b29tc2l6ZSwgaW50IHpvb21kaXIpIHsKICAgIGRv
dWJsZSBkeCwgZHk7CiAgICBkb3VibGUgbXgsIG15OwoKICAgIGRvdWJsZSB6b29tOwoKICAgIGlm
KHpvb21kaXIgPT0gMSAmJiB6b29tc2l6ZSAhPSAwKQogICAgICB6b29tID0gem9vbXNpemU7CiAg
ICBlbHNlIGlmKHpvb21kaXIgPT0gLTEgJiYgem9vbXNpemUgIT0gMCkKICAgICAgem9vbSA9IDEv
em9vbXNpemU7CiAgICBlbHNlCiAgICAgIHpvb20gPSAxLjA7CgogICAgZHggPSB0aGlzLm1heHgg
LSB0aGlzLm1pbng7CiAgICBkeSA9IHRoaXMubWF4eSAtIHRoaXMubWlueTsKICAgIG14ID0gdGhp
cy5taW54ICsgdGhpcy5jZWxsc2l6ZSp4OyAvLyBjb252ZXJ0ICpjbGljayogdG8gbWFwIGNvb3Jk
aW5hdGVzCiAgICBteSA9IHRoaXMubWF4eSAtIHRoaXMuY2VsbHNpemUqeTsKCiAgICB0aGlzLm1p
bnggPSBteCAtIC41KihkeC96b29tKTsKICAgIHRoaXMubWlueSA9IG15IC0gLjUqKGR5L3pvb20p
OwogICAgdGhpcy5tYXh4ID0gbXggKyAuNSooZHgvem9vbSk7CiAgICB0aGlzLm1heHkgPSBteSAr
IC41KihkeS96b29tKTsgCgogICAgdGhpcy5maXQoKTsKICB9CgogIHB1YmxpYyB2b2lkIGJveFpv
b20oZG91YmxlIHgxLCBkb3VibGUgeTEsIGRvdWJsZSB4MiwgZG91YmxlIHkyKSB7CiAgICBkb3Vi
bGUgbWlueCwgbWlueSwgbWF4eCwgbWF4eTsKCiAgICBtaW54ID0gdGhpcy5taW54ICsgdGhpcy5j
ZWxsc2l6ZSpNYXRoLm1pbih4MSwgeDIpOwogICAgbWlueSA9IHRoaXMubWF4eSAtIHRoaXMuY2Vs
bHNpemUqTWF0aC5tYXgoeTEsIHkyKTsKICAgIG1heHggPSB0aGlzLm1pbnggKyB0aGlzLmNlbGxz
aXplKk1hdGgubWF4KHgxLCB4Mik7CiAgICBtYXh5ID0gdGhpcy5tYXh5IC0gdGhpcy5jZWxsc2l6
ZSpNYXRoLm1pbih5MSwgeTIpOwoKICAgIHRoaXMubWlueCA9IG1pbng7CiAgICB0aGlzLm1pbnkg
PSBtaW55OwogICAgdGhpcy5tYXh4ID0gbWF4eDsKICAgIHRoaXMubWF4eSA9IG1heHk7ICAgIAoK
ICAgIHRoaXMuZml0KCk7CiAgfQoKICAvLyBjaGFuZ2VzIHRoZSBzaXplIG9mIHRoZSBtYXAgd2lu
ZG93ICh3aGljaCAqbWF5KiBjaGFuZ2UgdGhlIGV4dGVudCkKICBwdWJsaWMgdm9pZCByZXNpemUo
RGltZW5zaW9uIHNpemUpIHsKICAgIHRoaXMuc2l6ZSA9IHNpemU7CiAgICB0aGlzLmZpdCgpOwog
IH0KCiAgLy8gYWRqdXN0cyBhIG1hcCBleHRlbnQgdG8gZml0IGEgZ2l2ZW4gbWFwIHNpemUKICBw
dWJsaWMgdm9pZCBmaXQoKSB7CiAgICB0aGlzLmNlbGxzaXplID0gTWF0aC5tYXgoKHRoaXMubWF4
eCAtIHRoaXMubWlueCkvKHRoaXMuc2l6ZS53aWR0aC0xKSwgKHRoaXMubWF4eSAtIHRoaXMubWlu
eSkvKHRoaXMuc2l6ZS5oZWlnaHQtMSkpOwoKICAgIGlmKHRoaXMuY2VsbHNpemUgPiAwKSB7CiAg
ICAgIGRvdWJsZSBveCwgb3k7CgogICAgICBveCA9IE1hdGgubWF4KCgodGhpcy5zaXplLndpZHRo
LTEpIC0gKHRoaXMubWF4eCAtIHRoaXMubWlueCkvdGhpcy5jZWxsc2l6ZSkvMiwwKTsKICAgICAg
b3kgPSBNYXRoLm1heCgoKHRoaXMuc2l6ZS5oZWlnaHQtMSkgLSAodGhpcy5tYXh5IC0gdGhpcy5t
aW55KS90aGlzLmNlbGxzaXplKS8yLDApOwoKICAgICAgdGhpcy5taW54ID0gdGhpcy5taW54IC0g
b3gqdGhpcy5jZWxsc2l6ZTsKICAgICAgdGhpcy5taW55ID0gdGhpcy5taW55IC0gb3kqdGhpcy5j
ZWxsc2l6ZTsKICAgICAgdGhpcy5tYXh4ID0gdGhpcy5tYXh4ICsgb3gqdGhpcy5jZWxsc2l6ZTsK
ICAgICAgdGhpcy5tYXh5ID0gdGhpcy5tYXh5ICsgb3kqdGhpcy5jZWxsc2l6ZTsKICAgIH0KICB9
CgogIC8vIG1ldGhvZHMgdG8gY29udmVydCBwaXhlbCBjb29yZGluYXRlcyB0byBtYXAgY29vcmRp
bmF0ZXMKICBwdWJsaWMgamF2YS5hd3QuZ2VvbS5Qb2ludDJELkRvdWJsZSBwaXhlbFRvTWFwKGlu
dCB4LCBpbnQgeSkgewogICAgamF2YS5hd3QuZ2VvbS5Qb2ludDJELkRvdWJsZSBwb2ludCA9IG5l
dyBqYXZhLmF3dC5nZW9tLlBvaW50MkQuRG91YmxlKCk7CgogICAgcG9pbnQueCA9IHRoaXMubWlu
eCArIHRoaXMuY2VsbHNpemUqeDsKICAgIHBvaW50LnkgPSB0aGlzLm1heHkgLSB0aGlzLmNlbGxz
aXplKnk7CgogICAgcmV0dXJuKHBvaW50KTsKICB9CgogIHB1YmxpYyBkb3VibGUgcGl4ZWxUb01h
cFgoaW50IHgpIHsKICAgIHJldHVybih0aGlzLm1pbnggKyB0aGlzLmNlbGxzaXplKngpOwogIH0K
CiAgcHVibGljIGRvdWJsZSBwaXhlbFRvTWFwWShpbnQgeSkgewogICAgcmV0dXJuKHRoaXMubWF4
eSAtIHRoaXMuY2VsbHNpemUqeSk7CiAgfQoKICAvLyAjZGVmaW5lIE1TX01BUDJJTUFHRV9YKHgs
bWlueCxjeCkgKE1TX05JTlQoKHggLSBtaW54KS9jeCkpCiAgLy8gI2RlZmluZSBNU19NQVAySU1B
R0VfWSh5LG1heHksY3kpIChNU19OSU5UKChtYXh5IC0geSkvY3kpKQoKICBwdWJsaWMgZG91Ymxl
IG1hcFRvUGl4ZWxYKGRvdWJsZSB4KSB7CiAgICByZXR1cm4oKHggLSB0aGlzLm1pbngpL3RoaXMu
Y2VsbHNpemUpOwogIH0KCiAgcHVibGljIGRvdWJsZSBtYXBUb1BpeGVsWShkb3VibGUgeSkgewog
ICAgcmV0dXJuKCh0aGlzLm1heHkgLSB5KS90aGlzLmNlbGxzaXplKTsKICB9CgogIHB1YmxpYyBT
dHJpbmcgYXNTdHJpbmcoKSB7CiAgICByZXR1cm4odGhpcy5taW54ICsgIiwiICsgdGhpcy5taW55
ICsgIiwiICsgdGhpcy5tYXh4ICsgIiwiICsgdGhpcy5tYXh5KTsKICB9Cn0K
--=__PartECB22228.1__=--
