[Mapserver-users] MapServer 4.01 - unreadable error messages
thelen at ccgis.de
thelen at ccgis.de
Thu Jan 8 10:15:01 EST 2004
Hi all,
Actually according to the OGC specs mapserver should have used
"EXCEPTIONS=application/vnd.ogc.se_xml" as a default value if no other is
supplied. 3.6.x did, mapserver 4.x not. Is there a special reason for this
change?
Regards,
Benjamin
> We have solved the problem.
> We had a closer look at our request-URL and the OGC-Specs and added the
parameter "EXCEPTIONS=application/vnd.ogc.se_xml" (we did not use it
before
> because the OGC-Spec says that it is used as default-value) and now our
request looks like this and we get "readable" error-messages:
> http://192.168.2.90/cgi-bin/mapserv?map=/data/umn/germany_postgis1.map&WMTVE
R=1.0.0&REQUEST=feature_info&LAYERS=Topo,Grenze,Strassen,Staedtepunkte,Staed
tenamen&STYLES=default,default,default,default,default&SRS=EPSG:31493&BBOX=2
814061.782833395,5253088.015946961,3957426.454366242,6004441.94092474&WIDTH685&HEIGHT=450&FORMAT=png&TRANSPARENT=FALSE&FEATURE_COUNT=20&BGCOLOR=0xfffff
f&QUERY_LAYERS=Staedtepunkte&X=379&Y=277&INFO_FORMAT=text/html&EXCEPTIONS=ap
> Best regards,
> Christina
> -----Ursprüngliche Nachricht-----
> Von: Tyler Mitchell [mailto:TMitchell at lignum.com]
> Gesendet: Mittwoch, 7. Januar 2004 19:38
> An: Christina Biakowski
> Cc: Mapserver-Users at Lists. Gis. Umn. Edu
> Betreff: Re: [Mapserver-users] MapServer 4.01 - unreadable error messages
> mapserver-users-admin at lists.gis.umn.edu wrote on 01/07/2004 04:33:54 AM:
>> Dear list,
>> we have upgraded (OS: FreeBSD) from MapServer 3.66 to 4.01. Running
into
> an
>> error with the getfeatureInfo-request MapServer 4.01 returns the error
message in binary code using "content-type image/png", like:
>> Content-type: image/png ?PNG
>> IHDRÂ?ßRlPLTEÿÿÿUÂÓ~tIDATx?í]p×yÿÞÞ»Ó?@?·§Óù?xO9ÙK5гæ?N§oÅ.>
?¹Ã:ÐY©9ÁÝ fÄ?L?N35Ó?8ß? ÊIªC¦µbã Á...
>> With MapServer 3.66 we get "readable" error messages (Content-type:
text/html).
> Christina, is it possible for you to show us what the URL request was?
It
> may also be helpful to post your .map file. I'm wondering if it is
returning something like the mapserv executable. Strange... Are you
using
> php?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
