[Mapserver-users] Re: PROJECTION error in mapserver
Daniel Morissette
morissette at dmsolutions.ca
Thu Jan 8 18:08:38 EST 2004
Please send your questions to the mapserver-users list, that will give
you the best chances of getting a timely reply, and the solution to your
problem will be archived for others who may run into the same thing
later. I have CC'd this reply to the list.
Back to your question, this error message tells you that your 'mapserv'
CGI is not compiled with PROJ4 support. You didn't specify your
platform, but since all pre-built windows executables usually include
PROJ support, I assume that you are on Unix/Linux and compiled MapServer
yourself. You'll need to install PROJ4 on your machine, and then
reconfigure MapServer using --with-proj, and recompile it.
There may also be ways to run the tutorial without the PROJECTION stuff,
but I'mnot familiar enough with the tutorial to tell.
Daniel
travis at hpfm.com.au wrote:
> Hi There,
> I'm not sure if your the right person to ask but i'm not sure who can help
> me.
> I'm currently running through the tutorial for mapserver and have come
> accross this error message when trying to run my .map file:
> loadProjection(): Projection library error. Projection support is not
> available
> when i comment out the projection area of my map file eg:
> #PROJECTION
> # "proj=laea"
> # "ellps=clrk66"
> # "lat_0=45"
> # "lon_0=-100"
> # Alternatively, you can specify an EPSG code.
> # "init=epsg:2163"
> it seems to work however does not display anything in my browser except
> for an output image of the size i specify that is simply blank (the colour
> i specify in my map file) and thats all.
> If you could maybe suggest something or possibly point me in the right
> direction, it would be greatly appreciated.
> Regards
> Travis Klerck
