[Mapserver-users] Projection library error
travis at hpfm.com.au
Thu Jan 8 23:28:51 EST 2004
Hi there,
I seem to be having problems with PROJECTION while running the Mapserver
tutorial. i'm getting the error message:
loadProjection(): Projection library error. Projection support is not
available
it was suggested that i need to install PROJ4, i have and now i get the
error message:
Server error!
The server encountered an internal error and was unable to complete your
request.
Error message:
Premature end of script headers: mapserv
when i try to access the PROJ4 file on the linux server it doesn't work.
we get the httpd error log as below:
<error log>
error_log:[Fri Jan 09 14:53:45 2004] [error] [client 192.168.0.250]
/var/www/cgi-bin/mapserv: error while loading shared lib
raries: libproj.so.0: cannot open shared object file: No such file or
directory
error_log:[Fri Jan 09 14:53:56 2004] [error] [client 192.168.0.250]
directory
</error log>
<system>
root at hpfm01 httpd]# locate libproj.so.0
/usr/local/lib/libproj.so.0.4.1
</system>
we configured and compiled mapserver with the proj4 as instructed on the
instal but it doesn't work?
any suggesstions would be greatly appreciated.
regards
Travis Klerck
