[Mapserver-users] CLASS-level TRANSFORM & OFFSET?
Charlton Purvis
cpurvis at asg.sc.edu
Fri Jan 9 10:13:41 EST 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C3D6C3.2A462EEA
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Hi, folks:
I'm not saying that the following is the best approach, but it is, at
least, *an* approach.
Attached is a color bar centigrade legend. It's actually a bonafide
layer made up of a bunch of line segments and several labels. It all
sits neatly inside a postgis geometry table, and the LAYER is broken
down into a bunch of CLASSes to give the line segments specific RGB
values.
So this image is a collection of segments w/ specific pixel-based
(x,y)'s.
I do this because our color ramp is still in flux, and I don't want to
have to create a static .png every time our image changes. And it is
quite possible that once we're further along, the ramp, itself, will be
flexible in an ad-hoc basis. So it would be important that I keep the
image dynamic.
That being said, is there any way to use something like TRANSFORM NO and
something like OFFSET X Y at the LAYER level to tell MapServer where the
origin of that image coordinate's (0,0) should be?
Why? So I can keep the legend a true geometric LAYER as well as let my
WMS customers position it wherever they'd like in their image. (Perhaps
that 2nd statement is another thread.)
Thanks,
Charlton
=20
=20
=20
Charlton Purvis
(803) 777-8858 : voice
(803) 777-3935 : fax
cpurvis at sc.edu
=20
Baruch Institute
University of South Carolina
Columbia, SC 29208
Content-Type: image/png;
name="sst_legend.png"
Content-Transfer-Encoding: base64
Content-Description: sst_legend.png
Content-Disposition: attachment;
filename="sst_legend.png"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=
------_=_NextPart_001_01C3D6C3.2A462EEA--
