[Mapserver-users] itemquery doesn't find records
Nikolai Vladychevski
niko at isl.net.mx
Sun Jan 11 15:43:25 EST 2004
Hello,
I am trying about 4 hours to make an itemquery query without success. I
have tryed many qstring values but I still get:
"msQueryByAttributes(): Search returned no results. No matching record(s)
found." error.
I don't know what to do, can somebody give any tips how to debug this ?
This is my MapServer version:
MapServer version 4.0.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=TIFF
INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
This is the line in perl that I output to the browser:
print
$q->header(-location=>"http://$ENV{HTTP_HOST}/cgi-bin/mapserv?layer=enlaces&
layer=emplazamientos&map=".uri_escape("/var/www/html/map/my.map")."&scale=20
0&program=".uri_escape("/cgi-bin/mapserv")."&savequery=true&zoomdir=0&mode=i
temquery&qitem=".uri_escape("ID_EMPLAZ")."&qstring=".uri_escape("[ID_EMPLAZ]
'02-02290'")."&qlayer=emplazamientos&mapext=-117.124014+14.530688+-86.709056
+32.718120&codempl=02-02290&map_web_imagepath=".uri_escape("/var/www/html/tm
p/")."&map_web_imageurl=".uri_escape("/tmp/")."&zoomsize=2");
This is my map gobal extent:
EXTENT -117.124014 14.530688 -86.709056 32.718120
This is the layer definition
LAYER
NAME emplazamientos
DATA emplazamientos
DEBUG ON
STATUS OFF
TYPE POINT
TOLERANCEUNITS pixels
TOLERANCE 5
FILTERITEM 'ID_EMPLAZ'
FILTER '%codempl%'
CLASS
NAME 'emplazamientos'
COLOR 0 0 255
SYMBOL 'circle'
SIZE 5
TEMPLATE emplazamiento.html
END
END
The record exists:
[root at localhost map]# ogrinfo -al data/emplazamientos.shx |grep -A3 -B4
02-02290
OGRFeature(emplazamientos):9
NOMBRE (String) = Esperanza
LAT (Real) = -115.4952
LON (Real) = 32.6488
ID_EMPLAZ (String) = 02-02290
ID_CLASE (Integer) = 2290
POINT (-115.49517100 32.64879900)
The POINT is inside the extent:
-117.124014 (-115.49517100) -86.709056
14.530688 ( 32.64879900) 32.718120
The template file exists:
[root at localhost map]# cat emplazamiento.html
Emplazamiento: [ID_EMPLAZAM]:<br>
Nombre: [NOMBRE]<br>
Latitud: [LAT]<br>
Longitud: [LON]<br>
ID_Clase: [ID_CLASE]<br>
Full mapserver file:
MAP
NAME TRANSMISION
STATUS ON
IMAGETYPE PNG
SIZE 800 600
SHAPEPATH "data"
IMAGECOLOR 255 255 255
FONTSET fonts/fonts.list
WEB
HEADER map_header.html
TEMPLATE map.html
FOOTER map_footer.html
MINSCALE 0.001
MAXSCALE 200
IMAGEPATH "/var/www/html/tmp"
IMAGEURL "/tmp"
METADATA
WMS_TITLE "MapServer"
WMS_ABSTRACT "Despliege de Enlaces y Emplazamientos"
WMS_ACCESSCONSTRAINTS none
END
END
SCALEBAR
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 1
SIZE 100 2
COLOR 0 0 0
UNITS KILOMETERS
INTERVALS 2
TRANSPARENT FALSE
STATUS ON
END
QUERYMAP
SIZE 800 600
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
REFERENCE
IMAGE "mxmap.gif"
SIZE 250 155
STATUS ON
MAXBOXSIZE 246
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
PROJECTION
"proj=laea"
"ellps=clrk66"
"lat_0=23"
"lon_0=-110"
END
LAYER
NAME region
DATA region
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 255 255 255
OUTLINECOLOR 32 32 32
END
END
LAYER
NAME enlaces
DATA enlaces
STATUS ON
TYPE LINE
TOLERANCE 3
CLASSITEM "id_enlace"
LABELITEM "id_enlace"
SYMBOLSCALE 0.001
LABELMAXSCALE 0.1
CLASS
COLOR 0 255 0
OUTLINECOLOR 0 0 0
LABEL
TYPE TRUETYPE
ANTIALIAS TRUE
FONT arial
COLOR 0 0 0
BACKGROUNDCOLOR 255 255 230
SIZE 8
MINSIZE 8
MAXSIZE 12
ANGLE AUTO
POSITION CC
MINFEATURESIZE AUTO
BUFFER 2
END
TEMPLATE enlaces.html
END
END
LAYER
NAME emplazamientos
DATA emplazamientos
DEBUG ON
STATUS OFF
TYPE POINT
TOLERANCE 5
FILTER '%codempl%'
CLASS
COLOR 0 0 255
SYMBOL 'circle'
SIZE 5
END
END
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
END
