[Mapserver-users] Dead gallery links
Tyler Mitchell
TMitchell at lignum.com
Mon Jan 12 14:41:03 EST 2004
The UMN Mapserver applications Gallery is getting pretty septic. I ran a
link checker and found that ~ 22 of the 117 links on the page are dead or
have errors. I'm sure there are more which provide a nice error page that
the link checker didn't pick up on. Likewise, some of the errors are mere
timeout or redirection warnings which don't really throw an error.
In short, it would be good if those who have bad or dead links could pass
on the correct ones so they could get fixed. For your reference, I've
pasted my check results below. UMN guys, what's the process or who is the
contact for getting these fixed? Can you just remove the dead ones? It's
really bad for the mapserver project as a whole to have a public gallery
page that's out of date. I don't mind helping to weed out the bad links
to improve the page.
Fortunately the page was much better when I first viewed it years ago so I
didn't get turned off right away :)
Tyler
$ linkchecker http://mapserver.gis.umn.edu/gallery.html
LinkChecker 1.10.3 Copyright c 2000-2004 Bastian Kleineidam
LinkChecker comes with ABSOLUTELY NO WARRANTY!
This is free software, and you are welcome to redistribute it
under certain conditions. Look at the file `LICENSE' within this
distribution.
Get the newest version at http://linkchecker.sourceforge.net/
Write comments and bugs to calvin at users.sourceforge.net
Start checking at 2004-01-12 11:25:11-008
URL http://www.dnr.state.mn.us/hunting/deer/mapit.html
Name Deer
Finder
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 39, col 27
Real URL http://www.dnr.state.mn.us/hunting/deer/mapit.html
Check Time 4.819 seconds
Result Error: 404
URL http://maps.dnr.state.mn.us/mapserver_demos/tests/
Name MapServer Test Suite
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 54, col 27
Real URL http://maps.dnr.state.mn.us/mapserver_demos/tests/
Check Time 6.272 seconds
Result Error: 404 Not Found
URL http://terrasip.gis.umn.edu/projects/
Name TerraSIP Applications
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 87, col 27
Real URL http://terrasip.gis.umn.edu/projects/
Check Time 6.405 seconds
Result Error: (119, 'Operation now in progress')
URL http://cdcm.methaz.org/cdcm
Name Hurricane Hazard Information for Caribbean Coastal Construction
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 166, col 14
Real URL http://cdcm.methaz.org/cdcm
Check Time 4.431 seconds
URL http://www.puertogijon.es/Mapserver/gis.asp
Name Gijon Port Authority (Spain)
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 154, col 19
Real URL http://www.puertogijon.es/Mapserver/gis.asp
Check Time 7.316 seconds
Result Error: recursive redirection encountered:
=> http://www.puertogijon.es/error.htm
URL http://ils.io.inf.br/ier_map/ierf.htm
Name Estrada
Real, Brazil
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 147, col 19
Real URL http://ils.io.inf.br/ier_map/ierf.htm
Check Time 7.538 seconds
Warning Server 'Microsoft-IIS/5.0' has no anchor support, removing
anchor from request
Result Error: 404 Objeto nao encontrado
URL http://metadata.gd.itb.ac.id/sik/
Name Map of the Institute of Technology, Bandung,
In
donesia
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 199, col 12
Real URL http://metadata.gd.itb.ac.id/sik/
Check Time 2.113 seconds
Result Error: (7, 'getaddrinfo failed')
URL http://www.cartoweb.de
Name MapServer in a touristinformation-system
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 209, col 27
Real URL http://www.cartoweb.de/user/allgemein_start.php
Check Time 10.462 seconds
Info Last modified Mon, 12 Jan 2004 19:25:42 GMT
Warning URL path is empty, assuming '/' as path
Effective URL http://www.cartoweb.de/user/allgemein_start.php
Result Error: 401 Authorization Required
URL http://www.mohid.com/Prestige/Simulations_Gallery.htm
Name Modelling predictions of the Prestige oil spill.
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 317, col 12
Result Error: URL has whitespace at beginning or end
URL http://www.ns-verbrechen.at
Name Reason for eviction - non-Ayrian
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 330, col 12
URL http://mapserver.ocmlt.go.th/
Name NuMap/Thailand Traffic
Repo
rting
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 323, col 19
Real URL http://mapserver.ocmlt.go.th/
Check Time 6.476 seconds
URL http://www.nrm.qld.gov.au/lris/webgis/burnett/index.html
Name Burnett
Catchment Web GIS
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 391, col 19
URL http://213.201.25.155/mapes/navega.php
Name City Council of Girona
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 398, col 12
Real URL http://213.201.25.155/mapes/navega.php
Check Time 8.117 seconds
URL http://www.gaf.de/projects.html
Name GAF Global Experience
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 417, col 12
Real URL http://www.gaf.de/projects.html
Check Time 3.264 seconds
URL http://opengis.jrc.it
Name Melilla
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 457, col 19
Real URL http://opengis.jrc.it/
Check Time 6.401 seconds
URL http://www2.tetonwyo.org/mapserver/tc/
Name Teton County (Wyoming) Map Server
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 462, col 12
Real URL http://www2.tetonwyo.org/mapserver/
Check Time 5.085 seconds
Warning HTTP 301 (moved permanent) encountered: you should update this
link.
anchor from request
Effective URL http://www2.tetonwyo.org/mapserver/
Result Error: 403 Access Forbidden
URL http://www.ggh-mapservice.de/index.php3
Name GGH - Mapservice
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 423, col 19
Real URL http://www.ggh-mapservice.de/index.php3
Check Time 27.924 seconds
Result Error: more than five redirections, aborting
URL http://map2.fgdl.org/mapserver/start/thememaps.html
Name Florida Mapper
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 525, col 19
Real URL http://www.fgdl.org/mapserver/start/thememaps.html
Check Time 11.299 seconds
link.
Effective URL http://www.fgdl.org/mapserver/start/thememaps.html
URL http://www.dnr.state.mn.us/mapping/landview/
Name Minnesota DNR's LandView
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 567, col 12
Real URL http://www.dnr.state.mn.us/mapping/landview/index.html
Check Time 3.794 seconds
Warning Effective URL
Result Error: 404
URL http://wms.co.fulton.ga.us
Name Fulton County, Georgia Mapserver
Parent URL http://mapserver.gis.umn.edu/gallery.html, line 528, col 19
Real URL http://wms.co.fulton.ga.us/
Check Time 250.777 seconds
Result Error: timed out
Thats it. 22 errors in 117 links found
Stopped checking at 2004-01-12 11:30:41-008 ( 5.491 minutes)
