[Mapserver-users] HELP PLEASE URGENT!!, draw point in map
Ezequiel Bertone
ezeklinux at yahoo.com.ar
Mon Jan 12 17:43:59 EST 2004
Hello
I need draw a point in the map in coordinates XY.
The problem is that only draw the map without the
point. Where is the problem?
The coordinates XY is correct?
Thank you for you help.
I have the following map file an php file.
---- Php file
<?php
dl('php_mapscript.so');
$map_path="/var/www/html/";
$map=ms_newMapObj($map_path. "easu4.map");
$testlayer = $map->getLayerByName("reddot");
$testlayer->set("status", 1);
$testpt = ms_newPointObj();
$testpt->setXY(431,7195);
$image=$map->draw();
$testpt->draw($map, $testlayer, $image, 0, " ");
$image_url=$image->saveWebImage(MS_PNG,1,1,0);
<HTML>
<HEAD>
<TITLE>Esto es una prueba de Mapas </TITLE>
</HEAD>
<BODY>
<img SRC=<?php echo $image_url; ?>>
</BODY>
</HTML>
-- Map file
MAP
IMAGETYPE JPEG
EXTENT 430.0622899324 7194.39117490898 449.
418992570303 7210.068359375
SIZE 1200 1200
SHAPEPATH "data"
IMAGECOLOR 255 255 255
PROJECTION
"proj=utm"
"ellps=clrk66"
"datum=WGS84"
END
# Start of LAYER DEFINITIONS
SYMBOL
NAME "circle"
TYPE ellipse
FILLED true
POINTS
1 1 1
END
END
LAYER
NAME "reddot"
TYPE POINT
STATUS off
CLASS
Name "reddot2"
COLOR 255 0 0
SYMBOL "circle"
SIZE 40
END # CLASS
END # LAYER
LAYER # States polygon layer begins here
NAME au01
DATA asu01
STATUS DEFAULT
TYPE LINE
CLASS
COLOR 0 0 0
OUTLINECOLOR 32 32 32
END
END # States polygon layer ends here
END # end of map file/object
Los mejores usados y las más tentadoras
ofertas de 0km están en Yahoo! Autos.
Comprá o vendé tu auto en
http://autos.yahoo.com.ar
