[Mapserver-users] mapscript - strange behavior
Christoph Spoerri
spoerri at duke.edu
Tue Jan 13 12:38:52 EST 2004
Hi there,
I'm writing an application that let's user add point features to the map by
clicking on any location of the map. For this purpose I'm using the attached
code (Note: each click on the map results in a request to the server for a
new image).
The problem is that the first point (to be mapped) is not displayed on the
map. Yet when the user clicks on the map for the second time (to add a new
point) both points show up. When checking the .map files everything looks
fine: acetate layer is there, class definition looks fine and point
coordinates are there.
In case a predefine the acetate layer (w/ class def) in the base .map file,
the first point shows up just fine. Note: this solution is not an option
thought :(
any ideas? Thanks in advance,
Christoph
*********** code ********************
x = atof(param['x'])
y = atof(param['y'])
# create point object
ptCoord = getMapPoint([x,y],self._map)
ptObj = pointObj()
ptObj.x=ptCoord[0]
ptObj.y=ptCoord[1]
lnObj = lineObj()
lnObj.add(ptObj)
# create new point layer with class and add shape
mapImg=self._map.prepareImage()
lyrAcetate = self._map.getLayerByName('acetate')
if (not isinstance(lyrAcetate,layerObj)):
color = colorObj()
color.red = 255
color.green = 255
color.blue = 255
lyrAcetate = layerObj(self._map)
lyrAcetate.name = "acetate"
lyrAcetate.type = MS_LAYER_POINT
classTemp = classObj(lyrAcetate)
styl = styleObj()
styl.symbolname = "pin"
styl.size = 1
styl.maxsize = 1
styl.minsize = 1
styl.color = color
styl.backgroundcolor = color
styl.outlinecolor = color
classTemp.numstyles=1
classTemp.styles = styl
# create shape object and add point to shape object
shpObj = shapeObj(MS_SHAPE_POINT)
shpObj.add(lnObj)
shpObj.setBounds();
shpObj.index = 1
lyrAcetate.status = MS_ON
lyrAcetate.addFeature(shpObj)
lyrAcetate.draw(self._map,mapImg)
imagename = \
self._map.name+mapSession.id()+"_"+str(int(time()))+"."+mapImg.format.extension
mapImg.save(mapImg.imagepath+imagename)
