[Mapserver-users] Projection trouble
opengis_libero
opengis at libero.it
Wed Jan 14 05:39:12 EST 2004
This is a multi-part message in MIME format.
--------------040506040608060007010800
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 7bit
Stephen,
>TRY
> METADATA
> WMS_TITLE "Your title "
> WMS_SRS "EPSG:26932"
> END
>in your layer
Your suggest doesn't work fine: I've always blank map.
In attachement you can find shape file (like TeleAtlas data -- Polygon
of County or Parish) with *.prj file.
Does anyone can help me to use this shape with mapserver?
My environment:
win2000
Apache
MapServer version 3.6.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=EPPL7
INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
c:\proj
Secondary question:
How can test if my Proj4 work fine?
Content-Type: application/x-zip-compressed;
name="data.zip"
Content-Transfer-Encoding: base64
Content-Disposition: inline;
filename="data.zip"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--------------040506040608060007010800--
