[Mapserver-users] Error when querying PostGIS layer
Dylan Keon
keon at nacse.org
Wed Jan 14 10:56:01 EST 2004
I'm having trouble querying a PostGIS layer via PHP Mapscript. The
layer renders fine in the app and labels get generated, etc. But I get
an error when trying to query the layer. It fails when it reaches
getShape() - if I comment out that line everything else works. Also, if
I run this code on a shapefile version of the same layer it works fine.
I'm using MS 4.0.1, Postgres 7.4.1, PostGIS 0.8.1 on Linux. Thanks for
any help.
--Dylan
From the apache error log:
PHP Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'quad_index_24k'.
in /opt/httpd/htdocs/test.php on line 132
PHP Warning: [MapServer Error]: prep_DB(): Error executing POSTGIS
DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR
FOR SELECT
nf1::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text
from quad24k WHERE the_geom && setSRID('BOX3D(311625 301705,586625
577205)'::BOX3D, find_srid('','quad24k','the_geom') )' <br><br>
Postgresql reports the error ''<br><br>
More Help:<br><br>
Error with POSTGIS data variable. You specified '<check your .map
file>'.<br>
Standard ways of specifiying are : <br>
(1) 'geometry_column from geometry_table' <br>
(2) 'geometry_column from (<sub query>) as foo using unique
<column name> using SRID=<srid#>' <br><br>
Make sure you put in the 'using unique <column name>' and 'using
SRID=#' clauses in.
<br><br>For more help, please see
http://postgis.refractions.net/documentation.php
<br><br>Mappostgis.c - version of June 12/2003.
PHP Fatal error: Call to a member function on a non-object in
/opt/httpd/htdocs/test.php on line 133
// simple function for testing postgis layer query
function doQuery($map, $map_x, $map_y, $last_extent)
$layer = $map->getLayerByName('quad_index_24k');
$coords = pix2geo($map, $map_x, $map_y, $last_extent);
$geo = preg_split("/,/", $coords);
// create point object
$click_pt = ms_newPointObj();
$click_pt->setXY($geo[0], $geo[1]);
// query the map at the point clicked
@$map->queryByPoint($click_pt, MS_SINGLE, -1);
$count_results = $layer->getNumResults();
echo "count_results = $count_results<br>\n";
if($count_results > 0) {
$layer->open();
$result = $layer->getResult(0);
echo "<pre>getResult:<br>"; print_r($result); ech "</pre>";
$resultShape = $layer->getShape(-1,$result->shapeindex);
echo "<pre>getShape:<br>"; print_r($resultShape); echo "</pre>";
} else echo "No records returned";
$click_pt->free();
$resultShape->free();
LAYER
NAME quad_index_24k
TYPE POLYGON
CONNECTIONTYPE POSTGIS
CONNECTION "user=read dbname=oregon"
DATA "the_geom from quad24k"
STATUS ON
MAXSCALE 2400000
LABELMAXSCALE 600000
LABELMINSCALE 20000
TEMPLATE "null"
CLASS
OUTLINECOLOR 0 25 140
COLOR -1 -1 -1
COLOR 190 230 190
TEXT ([name] [nf1])
LABEL
WRAP " "
POSITION CC
SIZE SMALL
BUFFER 50
FORCE TRUE
MINFEATURESIZE 35
END
END
END
