[Mapserver-users] 2 MapServer Questions
Dylan Keon
keon at nacse.org
Wed Jan 14 13:32:15 EST 2004
Tom,
I'm not using Sybase SQS but I am using Sybase with MapServer to map
points from a user's query, and to provide data for each point. Tyler
is correct that this sort of thing is not supported "out of the box" in
the MapServer CGI. I use PHP's built-in Sybase functions along with PHP
MapScript to integrate the data with my MapServer app. But it sounds
like you're asking whether MapServer can display spatial features stored
in Sybase SQS - I'm not sure if SQS support is built in to MapServer.
IIRC, one of UMN's Fornet projects was using SQS in some form.
Regarding determining the extent of your shapefile: I use the shpdump
utility that comes packaged with shapelib (shapelib.maptools.org). I
just run 'shpdump <shapefile> | head' (on Linux or UNIX). The extent is
listed on the first few lines of output in the form of:
File Bounds: ( minx, miny)
to ( maxx, maxy)
'minx miny maxx maxy' is the format required by EXTENT in your mapfile.
You could also just use ArcExplorer or a similar GIS viewer to
determine the extent.
--Dylan
Tyler Mitchell wrote:
> I'd say this is a good question, Tom. I don't think that out of the box
> this is supported. But this brings a question to mind for me - is anyone
> using ODBC with MapServer (CGI not PHP)?
> Tyler
> mapserver-users-admin at lists.gis.umn.edu wrote on 01/13/2004 09:22:37 AM:
>>Hi All,
>>I am just beginning work with MapServer, and I have a few questions about
> it.
>>- My data is stored in a Sybase database with an SQS. Can I access
>>it with MapServer? If so, are there any examples?
>>- I am having a hard time figuring out the extent keyword under map.
>>Does anyone have any pointers about figuring this out for a .shp file?
>>Any help would be greatly appreciated. Thanks in advance for your
>>time and help.
>>-Tom
