[Mapserver-users] Projection trouble
opengis_libero
opengis at libero.it
Thu Jan 15 05:53:28 EST 2004
Stephen,
many thanks for your interest to my trouble.
Now my map work fine!
>please post your map file
NAME MyMap_right!
STATUS ON
SIZE 600 330
EXTENT 782712 4667376 861860 4740999
UNITS meters # <- problem is here, change DD in METER
SHAPEPATH "data"
FONTSET "./data/fonts.txt"
IMAGECOLOR -1 -1 -1
#PROJECTION
## "init=epsg:4318"
## proj=utm
## zone=32
## ellps=WGS84
## datum=WGS84
## a=6378249.200
## b=6356515.000
## towgs84=-263,6,431,0,0,0,0
## units=dd
# proj=tmerc
# ellps=WGS84
# zone=32
# "north"
# "no_defs"
## "proj=32761"
## proj=latlong
## ellps=clrk66
# END
LAYER
NAME layer_county
DATA Ri_pd
STATUS ON
TYPE POLYGON
# PROJECTION
# geographic
# END
# METADATA
# WMS_TITLE "Your title "
# "wms_srs" "EPSG:4326"
# END
CLASS
NAME 'County boundaries'
COLOR 220 220 255
OUTLINECOLOR 100 100 100 #gray
END
END
Remaining a mystery how mapserver realize right projection.
Have you any documentation or link to understand mapserver projection?
Best regards
PS.
I saw www.focus.ca : Have you got open source software in your solution?
