[Mapserver-users] Mapserver + PostGIS for dummies.
Jason M. Nielsen
jnielsen at aero-graphics.com
Thu Jan 15 13:39:48 EST 2004
First I would like to say mapserver and all its associated software is awsome.
Its incredible what a community can accomplish when working towards a common
goal using truly open standards. Very impressive.
Is there any holding your hand walk throughs on implementing a Mapserver +
PostGIS system? Looking for something where we can dump SHP files into the db as
well as rasters then view them.
At the moment I have mapserver compiled with most of the required options
(missing PHP/Mapscript support, having a hell of time getting it to compile due
to some axps deal in my current php setup), Postgresql is installed running and
being used, PostGIS is installed and appears to work.
I have actually dumped shp files into the database no problem with shp2pgsql but
I was never able to get the connection to work nor could I envision in my head
how it all linked together or would be. It appears there is something I have to
do with indexing but I havent the slightest clue where to begin or how it
applies to querying the PostGIS DB similar to just having shp files.
I have the demo working apparently perfectly and even setup my own map with
layers without a hitch using map and shp files.
Below is the error I get now when trying to pull the data from the postgis db. I
have tried "the_geom" and "geometry_column". I also queried the table and the
field name is "the_geom". The list 1 and 2(below) I do not understand what
exactly they are referring to. That is, where do I do this? What exactly is it?
http://postgis.refractions.net/docs/x556.html
I checked the above site and perhaps I am just not reading it carefully enough
but even once I create these indexes it seems like I need to do something
somewhere else if for no other reason than creating them had no affect on the
outcome of my query.
msDrawMap(): Image handling error. Failed to draw layer named 'Utah Geological
Study'.
prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query)
statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
s81 WHERE the_geom && setSRID('BOX3D(1781048.9509602
472006.998403,2143367.3005688 833751.562963)'::BOX3D,
find_srid('','s81','the_geom') )'
Postgresql reports the error ''
More Help:
Error with POSTGIS data variable. You specified '<check your .map file>'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column name> using
SRID=<srid#>'
Make sure you put in the 'using unique <column name>' and 'using SRID=#' clauses in.
For more help, please see http://postgis.refractions.net/documentation.php
Mappostgis.c - version of June 12/2003.
Where do these two "using" clauses go?
Thanks,
Jason Nielsen
This mail sent through IMP: http://horde.org/imp/
