[Mapserver-users] compile error
Yewondwossen Assefa
assefa at dmsolutions.ca
Thu Jan 15 18:19:58 EST 2004
There is a new version of map.h in CVS that you can get. The problem
seems to be the use of class which is a reserved word on some compilers.
If you do not have access, just the change the class by classobj (or
other non reserved name)
int msMoveStyleUp(classObj *class, int nStyleIndex);
int msMoveStyleDown(classObj *class, int nStyleIndex);
Later,
Randy James wrote:
> Hi
> I was trying to compile the nightly for 1/15/04 and was
> getting the error:
> In file included from mapogr.cpp:123:
> map.h:1319: parse error before 'int'
> map.h:1320: parse error before 'int'
> So I checked the map.h and guessed that maybe it should be
> layer rather than class because the rest in the section
> were layer. good guess or bad guess? well the compile
> worked anyway.
> i changed this
> int msMoveStyleUp(classObj *style, int nStyleIndex);
> int msMoveStyledown(classObj *style, int nStyleIndex);
> To:
> int msMoveStyleUp(classObj *layer, int nStyleIndex);
> int msMoveStyledown(classObj *layer, int nStyleIndex);
> I have a tiny bit of C programming experience, enough to
> know i do not know what i am doing anyway so, tell me what
> i did. ha ha
> Randy
> __________________________________
> Do you Yahoo!?
> Yahoo! Hotjobs: Enter the "Signing Bonus" Sweepstakes
> http://hotjobs.sweepstakes.yahoo.com/signingbonus
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
