[Mapserver-users] Error when querying PostGIS layer
Eric Bridger
eric at gomoos.org
Fri Jan 16 13:36:56 EST 2004
Yes. Runs fine in psql.
I suspect some mapserver/postgres/postGIS configuration/library issue
since it works on development but not on production.
But we are running postgis 0.7.5 on both machines.
On Fri, 2004-01-16 at 12:21, Dylan Keon wrote:
> To check your PostGIS version go to
> postgresql-7.x.x/contrib/postgis-0.x.x. In my case, I left the postgis
> directory name as postgis-0.8.1. Or you can look at the top lines in
> CHANGES or README.postgis.
> Yes, the SQL reported by PostGIS as an error runs fine from psql. Is
> that the same in your case?
> --Dylan
