[Mapserver-users] Geo TIFFs
Frank Warmerdam
warmerdam at pobox.com
Mon Jan 19 10:44:18 EST 2004
Jason M. Nielsen wrote:
> Now INPUT=TIFF is gone as I presume it should be since GDAL will be being used?
Sounds good.
> Samething still occures. No errors. Image just simply does not display.
> [root at vad3rZIM data]# gdalinfo top10c0.tif
> Driver: GTiff/GeoTIFF
> Size is 3854, 3773
> Coordinate System is `'
> Origin = (1512385.000000,7356162.500000)
> Pixel Size = (10.000000,-10.000000)
> Metadata:
> TIFFTAG_SOFTWARE=Adobe Photoshop 7.0
> TIFFTAG_DATETIME=2004:01:14 09:03:52
> Corner Coordinates:
> Upper Left ( 1512385.000, 7356162.500)
> Lower Left ( 1512385.000, 7318432.500)
> Upper Right ( 1550925.000, 7356162.500)
> Lower Right ( 1550925.000, 7318432.500)
> Center ( 1531655.000, 7337297.500)
> Band 1 Block=3854x2 Type=Byte, ColorInterp=Red
> Band 2 Block=3854x2 Type=Byte, ColorInterp=Green
> Band 3 Block=3854x2 Type=Byte, ColorInterp=Blue
The first conclusion I leap to is that your map extents are wrong with regard
to the raster file. If you want further help it would be best to supply your
complete mapfile, or a minimal complete mapfile that demonstrates your problem.
I would also encourage you to run the mapfile through "shp2img" with as much
debugging turned on as possible.
eg.
$ export CPL_DEBUG=ON
> BTW, while Im on the subject and have the gdal info up here. I do not recall
> seeing anyplace where I can directly reference this "Metadata:" section in the
> TIFF. Is this possible through mapserv directly or would a script of the like
> need to be written (ie: perl, php, python etc) that made use of the likes of
> gdal_info to extract said information?
The metadata provided by GDAL is not trivially usable within MapServer. However,
it is accessable via the C/C++ and Python APIs for GDAL (perhaps the PHP bindings
too? Though I think they may only exist for OGR, not GDAL). You could also
run gdalinfo externally and parse the output but thats kind of a clumsy solution.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
