[Mapserver-users] Change layerobj's data property
Homme Zwaagstra
hrz at geodata.soton.ac.uk
Mon Jan 19 11:10:51 EST 2004
Thanks for the reply but I'm afraid your tip didn't work for me - on to the
upgrade!
Homme.
> I use this method with Mapserver/mapscript 3.6.6 with no problems.
> But I don't rely on mapscript to use the SHAPEPATH, I always use the
> full path for the layer->data member. Try that. You should be able to
> retrieve the SHAPEPATH from the map object $map->shapepath.
> Eric
