Hi list, is it possible to define variables in a MAP file and then use them throughout the MAP file, i.e. when you have 10 WMS layers which all come from the same URL, you want to define this URL only once in your MAP file and not at every LAYER? I am looking for an option without using Mapscript. Best regards, Bart
