[Mapserver-users] Error with Postgis data variable
Pericles S. Nacionales
nacional at cbs.umn.edu
Tue Jan 20 22:14:07 EST 2004
These might be what you're looking for:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00331.html
You might also want to look at the original message:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00291.html
Cheers!
Perry N.
On Tue, 2004-01-20 at 19:54, Matthew Haines wrote:
> I'm having what seems to be a very common problem, but I've stripped the
> code down to the bone and am at a loss as to what to do next. I've read the
> archives for three hours now and am not finding anything.
> Mandrake 9.2 Linux, PostgreSQL 7.4, Postgis 0.8.0, Mapserver 4.0.1
> I've chopped my .map file down to the bone:
> LAYER
> NAME "bk_taxlots"
> CONNECTIONTYPE postgis
> CONNECTION "user=website dbname=nycpr"
> DATA "the_geom from brooklyn_taxlots"
> MAXSCALE 25000
> TYPE POLYGON
> STATUS DEFAULT
> CLASS
> NAME "Residential, 1-2 Fam"
> OUTLINECOLOR 32 32 32
> END
> END
> and I'm executing shp2img and get this:
> msDrawMap(): Image handling error. Failed to draw layer named 'bk_taxlots'.
> <br>
> prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query)
> statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
> asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from
> brooklyn_taxlots WHERE the_geom && setSRID('BOX3D(997814 178997,999214
> 180397)'::BOX3D, find_srid('','brooklyn_taxlots','the_geom') )' <br><br>
> Postgresql reports the error ''<br><br>
> More Help:<br><br>
> Error with POSTGIS data variable. You specified '<check your .map
> file>'.<br>
> Standard ways of specifiying are : <br>
> (1) 'geometry_column from geometry_table' <br>
> (2) 'geometry_column from (<sub query>) as foo using unique <column
> name> using SRID=<srid#>' <br><br>
> Make sure you put in the 'using unique <column name>' and 'using
> SRID=#' clauses in.
> _________________________________________________________________
> High-speed usersbe more efficient online with the new MSN Premium Internet
> Software. http://join.msn.com/?pgmarket=en-us&page=byoa/prem&ST=1
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Pericles S. Nacionales <nacional at cbs.umn.edu>
University of Minnesota
