[Mapserver-users] Re: VirtualSpatialData (OGR Connectiontype)
Normand Savard
nsavard at dmsolutions.ca
Wed Jan 21 17:25:48 EST 2004
Julien,
Just because I do not know all the steps you have done, can you tell me
if you were able to have some output form "ogrinfo" command?
Norm
Julien, Heryk wrote:
>Hi Paul,
>What do I write in the virtual file SrcDataSource tag when I log on a Access
>db with no user restrictions and pass word?
>I've tried the following combinations without success:
><SrcDataSource>ODBC:MGWI_MAPSERVER</SrcDataSource>
><SrcDataSource>ODBC:@MGWI_MAPSERVER</SrcDataSource>
><SrcDataSource>ODBC:/@MGWI_MAPSERVER</SrcDataSource>
><SrcDataSource>ODBC:administor/@MGWI_MAPSERVER</SrcDataSource>
><SrcDataSource>ODBC:administeur/@MGWI_MAPSERVER</SrcDataSource>
>Thanks
>Héryk
>-----Message d'origine-----
>De : Paul Spencer [mailto:pagameba at magma.ca]
>Envoyé : Wednesday, January 21, 2004 1:43 PM
>À : Julien, Heryk
>Cc : 'spencer at dmsolutions.ca'; 'Mapserver-users at lists.gis.umn.edu';
>Anctil, Martin
>Objet : [Mapserver-users] Re: VirtualSpatialData (OGR Connectiontype)
>I believe there is a limitation in the OGR OBDC connection that requires
>that you provide a user name and password in the OVF file (I think that
>is mentioned in the wiki also).
>Cheers,
>Paul
>>Hi,
>>I'm trying out the Virtual Spatial Data procedure in MapServerWiki
>>(http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData) with IIS
>>and an Access 2000 ODBC connection.
>>I keep on getting the following error message when I attempt ton see my
>map:
>>msDrawMap(): Image handling error. Failed to draw layer named
>'MGWI_TBLLOC'.
>>msOGRFileOpen(): OGR error. Open failed for OGR connection `mgwi.ovf'.
>File
>>not found or unsupported format.
>>Anyone can help me?
>>Here is my virtual file (mgw.ovf):
>><OGRVRTDataSource>
>> <OGRVRTLayer name="MGWI_TBLLOC">
>> <SrcLayer>tblloc</SrcLayer>
>> <GeometryType>wkbPoint</GeometryType>
>> <!-- LayerSRS>WGS84</LayerSRS !-->
>> <GeometryField encoding="PointFromColumns" x="x" y="y"/>
>> </OGRVRTLayer>
>></OGRVRTDataSource>
>>My virtual layer is in the same directory as my shapefiles:
>>SHAPEPATH "d:\webcgcq\lcnp\mapserver_demo\maritimes\data\shp\geo83"
>>Here is the section of my mapfile where I call my virtual layer:
>>LAYER
>> NAME "MGWI_TBLLOC"
>> TYPE POINT
>> CONNECTIONTYPE OGR
>> CONNECTION "mgwi.ovf"
>> DATA "MGWI_TBLLOC"
>> STATUS DEFAULT
>> LABELITEM "LOCID"
>> PROJECTION
>> "init=epsg:26920"
>> END #projection
>> CLASS
>> SYMBOL 'circle'
>> SIZE 8
>> LABEL
>> COLOR 132 31 31
>> SHADOWCOLOR 218 218 218
>> SHADOWSIZE 2 2
>> TYPE TRUETYPE
>> FONT arial-bold
>> FORCE true
>> SIZE 10
>> POSITION auto
>> PARTIALS FALSE
>> MINDISTANCE 0
>> BUFFER 2
>> END # end of label
>> TEMPLATE
>>"d:\webcgcq\lcnp\mapserver_demo\maritimes\templates\field_capt_query.html"
>> END # CLASS
>>END # LAYER
>>Héryk
>>NRCan
>>De : Julien, Heryk [mailto:hjulien at nrcan.gc.ca]
>>Envoyé : Wednesday, January 14, 2004 8:44 AM
>>À : 'spencer at dmsolutions.ca'
>>Cc : 'Mapserver-users at lists.gis.umn.edu'
>>Objet : RE: TR: [Mapserver-users] MySQL and Mapserver
>>Thanks
>>Héryk
>>Envoyé : Tuesday, January 13, 2004 5:00 PM
>>À : Julien, Heryk
>>Cc : 'Paul Spencer '; 'Mapserver-users at lists.gis.umn.edu'
>>Objet : Re: TR: [Mapserver-users] MySQL and Mapserver
>>Maybe you missed it?
>http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00111.html
>>Cheers,
>>Paul
>>>Hi Paul,
>>>Could you send me or post information on the "new format in
>>>OGR to set up a virtual layer that can draw columns from any ODBC data
>>>source and map two of the columns to x and y locations"?
>>>Thanks
>>>Héryk
>>>Envoyé : Monday, January 05, 2004 9:23 AM
>>>Objet : RE: [Mapserver-users] MySQL and Mapserver
>>>Hi,
>>>I am also very interseted in that fonction. I would like to be able to map
>>>well positions from a database x and y colums. Would this permit me to
>>have
>>>an up to date point geometry layer which reflects the changes in my well
>>>database? Can you send me more details?
>>>Thanks
>>>Héryk
>>>NRCan
>>>Envoyé : Saturday, January 03, 2004 4:28 PM
>>>À : bartvde at xs4all.nl
>>>Cc : mapserver-users at lists.gis.umn.edu
>>>Objet : Re: [Mapserver-users] MySQL and Mapserver
>>>Bart,
>>>if you are interested in point geometries only, there is a new format in
>>>source and map two of the columns to x and y locations. We've used it
>>>for a couple of clients and it works very nicely. If you are interested
>>>I can send you more details.
>>>Cheers,
>>>Paul
>>>Bart van den Eijnden wrote:
>>>>Hi list,
>>>>I see in the history log that there has been some work done recently
>>>>(early December) by Attila on supporting MySQL 4.X for the MyGIS
>>>>connector. Can it be used already?
>>>>Also, is it possible to keep the geometries in shapefiles and use
>>>>Mapserver JOINS to link to tables in MySQL?
>>>>Thanks in advance for the info.
>>>>Best regards,
>>>>Bart
>>>>_______________________________________________
>>>>Mapserver-users mailing list
>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
