[Mapserver-users] Problem building the Java Mapscript module
Jean-Henry Berevoescu
bjh at globexplorer.com
Thu Jan 22 19:37:22 EST 2004
Jim Buzbee wrote:
> Jean-Henry Berevoescu wrote:
>> Hi,
>> I recently saw a message about this problem and I tried to
>> fix the problem with the paches as indicated
>> (http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?ObtainingAndInstallingTheSoftware)
>> The problem is still there.
>> Any hint/tip will be greatly apreciated.
> Comments below, (from memory, may not be completely accurate )
> Basically you just need to fix the errors and rebuild that portion...
OK. I did just that. With the first two errors it is pretty
straightforward, since they are definitely duplicates. But the "clone"
thing - I don't know. It might affect something else?
Anyway I compiled and will try to use it in a little test.
Thanks a lot,
Jean
