TR: [Mapserver-users] Re: VirtualSpatialData (OGR
Connectiontype)
David Fawcett
David.Fawcett at state.mn.us
Fri Jan 23 14:45:08 EST 2004
Heryk,
I haven't tried to connect to Access 2000, but a couple of thoughts.
Is your database 'secured' with Access security? Is there an argument in the connection string to identify the path to the security file (system.mdw) that the database file uses?
If it is secured, maybe try creating a very simple, unsecured database to connect to. You would then pass it a user name of 'admin' and a null password.
Have you hit this ODBC datasource using any other program?
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> "Julien, Heryk" <hjulien at nrcan.gc.ca> 1/23/2004 1:23:01 PM >>>
Has anyone ever tried connecting to Access 2000?
That may be the problem.
Is so I'll have to use a different db software!
Unfortunatly almost everyone in my office works with Access 2000.
Thank you all for your patience and help
Cheers
Héryk
-----Message d'origine-----
De : Arthur, John [mailto:John.Arthur at T-Mobile.com]
Envoyé : Friday, January 23, 2004 2:09 PM
À : 'Julien, Heryk'; 'Frank Warmerdam'
Cc : 'Zak James'; 'Normand Savard'; 'Mapserver-users at lists.gis.umn.edu';
Anctil, Martin; 'spencer at dmsolutions.ca'
Objet : RE: [Mapserver-users] Re: VirtualSpatialData (OGR
Connectiontype)
I'm using windows with MSSQL for this one. In your CONNECTION tag, try
using "/" instead of "\":
"D:/webCGCq/lcnp/mapserver_demo/maritimes/data/shp/geo83/mgwi.ovf"
-----Original Message-----
From: Julien, Heryk [mailto:hjulien at nrcan.gc.ca]
Sent: Friday, January 23, 2004 2:03 PM
To: 'Frank Warmerdam'; Arthur, John
Cc: 'Zak James'; 'Normand Savard'; 'Mapserver-users at lists.gis.umn.edu';
Subject: RE: [Mapserver-users] Re: VirtualSpatialData (OGR
Connectiontype)
Okay,
If run the orginfo with the ODBC connection name (MGWI_TBLLOC) instead of
the Access table name (tblloc) I get my table content. Thanks.
Now I'm back to the original problem. All the components seem to work
perfectly but I keep on getting the same error message when I try to draw
the map:
msDrawMap(): Image handling error. Failed to draw layer named 'MGWI_TBLLOC'.
msOGRFileOpen(): OGR error. Open failed for OGR connection
`D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf'. File not
found or unsupported format.
It doesn't seem to find the mgwi.ovf file. I tried both relative and
absolute paths. I checked my mapfile and everyting seems okay
LAYER
NAME "MGWI_TBLLOC"
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
"D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf"
DATA "MGWI_TBLLOC"
STATUS default
LABELITEM locid
PROJECTION
"init=epsg:26920"
END #projection
CLASS
SYMBOL 1
SIZE 8
COLOR 255 0 0
LABEL
SIZE MEDIUM
TYPE BITMAP
COLOR 0 0 0
END # end of label
END # CLASS
END # LAYER
John, are you using an Access database? Are you working on Linux or Window?
Thank you all for your help
Héryk
mgwi.ovf:
<OGRVRTDataSource>
<OGRVRTLayer name="MGWI_TBLLOC">
<SrcDataSource>ODBC:MGWI_MAPSERVER,tblloc</SrcDataSource>
<SrcLayer>tblloc</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="X" y="Y"/>
</OGRVRTLayer>
</OGRVRTDataSource>
De : Frank Warmerdam [mailto:warmerdam at pobox.com]
Envoyé : Friday, January 23, 2004 10:24 AM
À : Julien, Heryk
Cc : 'Zak James'; 'Arthur, John'; 'Normand Savard';
'Mapserver-users at lists.gis.umn.edu'; Anctil, Martin;
Objet : Re: [Mapserver-users] Re: VirtualSpatialData (OGR
Connectiontype)
Julien, Heryk wrote:
> Hi,
> I tried it and I don't get the table content!
> Firt try:
> D:\WebScripts\MapServer>ogrinfo
> ERROR 4: Update access not supported for VRT datasources.
> Had to open data source read-only.
> INFO: Open of
> using driver `VRT' successful.
> 1: MGWI_TBLLOC (Point)
> Second try with the table name:
> D:\webCGCq\lcnp\mapserver_demo\maritimes\data\shp\geo83\mgwi.ovf tblloc
> INFO: Open of
> The table doesn't seem to be coming through! Any idea?
> I tried the new build that Paul made available this morning and I get the
> same problem!
I'm not sure if I missed some of the email on this thread (it is pretty
overwhelming!) but you didn't use the correct table name in your ogrinfo
query. When you ran ogrinfo without the layer name you got "1: MGWI_TBLLOC
(Point)" as the result. The "MGWI_TBLLOC" portion of this is the layer
name. So you should use it, not TBLLOC as the layer name in your ogrinfo
query:
Good luck,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
Mapserver-users mailing list
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
