[Mapserver-users] WMS Capabilities and ScaleHint
Daniel Morissette
dmorissette at dmsolutions.ca
Mon Jan 26 10:07:52 EST 2004
Christina Biakowski wrote:
> Hello,
> we would like to use the ScaleHint-tag of the WMS Capabilities-Document for
> some functions in our WMS Client.
> For example I have a layer with
> MINSCALE 0
> MAXSCALE 6000000
> using a planar projection (Gauss-Krüger (epsg:31493), map units meters).
> This is what I get in the Capabilities-document:
> - <Layer queryable="0">
> <Name>patch</Name>
> <Title>patch</Title>
> <SRS>epsg:31494</SRS>
> <LatLonBoundingBox minx="10.8144" miny="49.2336" maxx="11.432"
> maxy="49.6507" />
> <BoundingBox SRS="EPSG:31494" minx="4.41439e+006" miny="5.45572e+006"
> maxx="4.45865e+006" maxy="5.50159e+006" />
> <ScaleHint min="0" max="2993.42" />
> </Layer>
> Now I wonder in which units the ScaleHint is displayed, I tried it with inch
> an miles but it does not fit.
This Scalehint thing is always confusing. Here is the theory:
The WMS defines the scalehint values as the ground distance in meters of
the southwest to northeast diagonal of the central pixel of a map.
ScaleHint values are the min and max recommended values of that
diagonal. (See WMS 1.1.0 sect. 7.1.5.4)
The units aren't defined by the spec, but looking at the code, it seems
that MapServer uses meters as the units for the Scalehint value and
that's probably what most servers use. So the Layer definition above
means that this layer can be served at scales that result in pixel
diagonal sizes ranging from 0 to 2993 meters.
In the WMS 1.2/1.3 spec (to be released soon hopefully), the ScaleHint
will be replaced by MinScaleDenominator and MaxScaleDenominator which
makes much more sense. You can already find the definition of those two
elements in the SLD 1.0 specification.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
